I'm sure someone can help with this one.
When performing oil changes (any vehicle) I always used to prime the engine oil circuit by turning over on the starter with the ignition disabled to prevent firing. In the old days it was just a case of pulling off a coil LT wire but with modern integrated electronics it's not so easy!
So my question is, what's the easiest way of preventing my 2011 Panda 1.2 from starting but still allowing it to crank on the starter?
I would guess that it's a case of removing a relay or fuse, but which one?
Martin.
Martin.
