- Mar 17, 2008
- 47
- 9
Hi all, I wonder if anyone has solved the following problem? When I unlock my Panda (via the remote) all internal door handles flip out as usual, however the front passenger door cannot be opened from the outside. If I open the door from the inside then close it again the exterior handle now works.
The electronic servo seems to be OK as the interior handle flips to the unlocked position when using the central locking.
I searched the forums and found someone with a similar problem but it was never answered. (can't post URL but the thread is called '1.2 dynamic passenger side lock problem')
Using eLearn I got as far as removing the interior trim and peeling back the waterproofing panel but have reached the stage of drilling rivets to remove the tamper protection so have stopped.
My experience of small cars in general leads me to believe some tiny piece of plastic has probably broken which will necessitate the replacement of the entire door or something :shakehead:
Anyway, if anyone has any ideas that would be useful, failing that it is due a service soon so I may just have to pay the dealer $$$ to fix it Ahhhh
Cheers,
Mint.
Cheers,
Mint.
