Thought I'd share my experience if it's of any use.
Just done similar work on mine. Following £84 charge for diagnosis, garage wanted £480 just to strip to diagnose further after error codes P0238 Air supply circuit anomally, P0400 EGR valve check and P1102 Air flow meter signal. I decided to look at it myself - New EGR fitted ( e-bay) - though I don't think it was necessary except one socket screw sheared when trying to remove EGR body from heat exchanger. Intake manifold was very 'gunged up' and I cleaned this and MAP sensor and all pipework from and to intercooler. I also found that plastic pipe from air filter to turbo was broken where crankcase breather pipe enters it, which I think they did when they changed MAF sensor last year, in third year warranty, when I reported car was running poorly. Since then it has got worse so i took it for the diagnosis. Should have bought a EOBD reader!
Anyway, also found, like others,that there was oil in pipe work from turbo to intercooler and to inlet manifold. I was worried that turbo seals might have gone, but decided to put it back together, with new pipe and gaskets, as turbo can be changed without having to remove so many ancillaries and drain coolant. At the moment it is back to full performance, although, after 200 miles, there's a film of oil in pipe from turbo to intercooler - it would be nice to know fiat's view on how much oil mist gets from crankcase ventilation normally.
Passed smoke test in MOT -0.52/m, few days ago, so can't be too bad.
Seems that new turbo can be had for less than £250, plus a few pipes and gaskets needed to do the job.
My son has my old corsa with this engine, which after 75000 miles is very smoky at low revs, so may give it a similar 'birthday treat' at some time in the future.
