Pandablues
Member
Quite surprised that there's no "how to" on changing the front pads. I've searched and found lots of "it's easy" comments, but not a single "that's the way to do it". So,,,,is it remove the "R" clip, knock out the pin and swing the caliper away, strip out the old and in with the new, shlop some brake grease about and refit? Or are there caveats? Does the piston need pushing back and if so, how. Any need to release brake fluid? Any help appreciated ta.
And no, I don't need new discs, and yes, I do know where not to put grease - just got a slightly binding brake so thought to bung in new pads at the same time.
