No.
Is it an allen or one of the torq headed feckers?
I'd say it'd be on the biggish side, 6 to 8mm.
I can check when it's light.
How's this turned into a insurance brawl??
Bri is against anyone doing anything on their own car
No.
There is a download section here:There was even links to download Jags TIS, Electronic parts list, handbooks, service guides and so on.
Maybe it's time to do some write ups of regular jobs.
Care to actually help people rather than do this whole holier than thou thing and not help?Some of the answers to this question are completely wrong. I posted a reply to someone who had tackled the same job in completely the wrong way, causing damage to the rubber boots. He had more expense to put things right, and brakes are not something to take lightly, lives can depend on them! Many people replace brake pads without realising that the discs are also in poor condition, if they are worn down to 1mm below the original thickness they need replacing (I have a ventilated brake disc off someones vehicle which shattered into several pieces, a solid disc is less likely to brake up quite so badly). Instructions using photos showing what to look for and what to do might be a good idea, but if in doubt ask someone qualified to show you, don't rely on just anything you are told.
Now all I need is a tuit
Any tips on how to release the pin on the caliper. Have removed the r clip but the pin is sold even with some WD-40 and a wack with a hammer. I have been having a binding issue so want to have a look - the pads were kwik-fit fitted (I know, I know) as were the discs so I intend to give the lot a bloody good clean and replace the pads as well as the binding is much worse on the drivers side so the pads are bound to be uneven. It was bad enough to make the wheel trim too hot to touch on a 30 mile drive the other day!
Would adding some heat to the oin help with its release?
Some punches are very helpful for punching the pin throughGot it sorted. Ended up using a combination of wheel cleaner (to break down the copious break dust), a wire brush, penetraing fluid, and a lighter! Came out with a couple of swift taps!
Was really good of the idiots at kwik fit to put no grease at all on anything. No wonder the breaks where binding and squeaking - I had to use a hammer to get the pads out as they were absolutely solid. Drivers side pads had turned white (I assume due to the heat) and very badly glazed, but all is good now and the discs were fine.
New mintex pads in, loads of copper grease on anything that moves, and the car is stopping better than ever with no squeaks at all! Just shows if you want it done right do it yerself!
Even that didnt work! Seriously. Was beginning to think KF had welded them on lolSome punches are very helpful for punching the pin through
