Bannedbiker
- Oct 5, 2015
- 6
- 1
Cool, so the current shape you can buy new still? I assume it is, being a pop.
If so then like you say, as you've a motor in the drivers door lock it should be a lot easier for you. You just need to find the feed in the wiring loom to the door for the lock and unlock signal
We have found two wires in the door loom; a black/white and an orange/green. One at a time shows a +12v compared to the chassis earth when the doors are un/locked, HOWEVER, if we then put a +12v signal to either wire to make the car un/lock, nothing happens!
Any ideas?
