billybudge
Banned
- Feb 27, 2011
- 22
- 7
Hi all;
I have owned a Fiat Panda 1.2 dynamic since new, 2004 model, I have always serviced it myself, now it is touching nearly 35k, passed every MOT no problems, this year though, I had to replace. tie/track rod ends, fr wheel bearings, pads and discs,
this is the 3 set of pads since new and I have now fitted Brembo, they are fantastic. really recommend these, you can feel the difference,
I had a gearbox problem last week or so, I changed the clutch, this is when I noticed that the gearbox linkage turet was bent and worn, I replaced this along with the clutch, bearing and also the release bearing fork arm,
Wow, what a difference, really the car flies, really responsive, I mean really responsive,
I fitted the Borg and Beck clutch kit,rather than the AP clutch kit, very highly recommeded, very noticable increase in performance, when I fitted the bearing fork arm I moved it 3 notches towards the clutch slave, now the gear change is fast you only have to dab the pedal to change gear,
I also made a quick shift gear lever, superb, and easily done,
Also I fitted a few years ago a K and N cone filter. I made My own induction box,,
so performance wise. the rolling road test, orginal figure was bhp69 from new, added the air filter 4 years ago, then bhp was 76 at the wheels, todays reading is a monster 107bhp at the wheels, wow, it was tested twice same reading,
so the message here is, it is not how much you spend on your car it what you do that counts,
