First post here - hoped it would be more positive, but can't be helped.
We have an 04 plate Panda 1.2 Eleganza - the reliable, economical runabout to go with our '93 Defender 110 V8i - which is neither particularly reliable nor economical! ;-)
Anyhow, three weeks ago I managed to drown the poor Panda in a local ford - the water was higher than usual, but not unduly so, but this ford has a bend in it and when I came around the bend the road was blocked by an abandoned 5 series so we had to stop, the bow wave collapsed and then the engine stopped.
After a quick spot of ice-cold wading I got home and, with the help of a friend, used the 110 to pull the Panda out of the ford and back home. Next day I pulled the spark plugs and turned the engine over on the starter and got a nice little fountain from the cylinders. A bit of compressed air down the plug holes, dried the plugs and then a whiff of damp start got the engine running again, smoothly enough but the revs kept climbing and dropping, sometimes to a stall. So next step was to pull off the inlet manifold and throttle body and take them into the house, along with the ECU, for some quality drying time. I also drained the oil (slightly mayonnaisey) and changed the filter as well. The check engine light was also lit, along with the display telling me 'Engine Failure'
Last weekend I put everything back together again, fresh oil, and she was much more happier - cold idle at 1200rpm, dropped to 850rpm hot, no hunting, but still check engine lit and 'engine failure' on the display - I figured this was probably something that would need the dealer to plug in their box of tricks to reset. Went for a drive around for 10 mins, local streets and some 60mph on the local dual carriageway - all fine, pick-up as normal, no hesitation, all good.
Friday, first time since last Saturday, I decided to drive into work to collect the seats which had been drying in an air-coned server room (air-con set to 'dry' - works well if you ever have something really wet to dry out). I got about 300m down the road when the engine seemed to loose all power - still turning at maybe 2000rpm but no 'go'. This lasted a few seconds, then there was a surge of power for a second or so, then back to no power. This continued - nothing, surge, nothing, surge while I turned around and crawled home at 5mph. Once I'd parked-up she sat there idling quite happily.
I'm not really sure what can be causing this, especially after she ran fine last weekend. I'm clutching at straws but thinking maybe either water in the fuel or the catalyst got cracked by the thermal shock as water went up the exhaust once the engine stopped and now the bits of catalyst are blocking the exhaust - clutching at straws, as neither explains why she was fine last week and not now. I looked for a drain plug on the petrol tank, but there doesn't seem to be one - I suppose I could pump it out using the injection pump and a jumper in the relay box?
Does anyone have any ideas before I admit defeat and head to the main dealer in town?
Cheers,
Andrew.
Cheers,
Andrew.
