General Cigarette Lighter
Jonty3
Hi all!
Could someone help / link me to somewhere with some information on fitting a cig lighter socket so I can plug my FM transmitter in?
I know on higher spec Panda's its between the Handbrake and the cup holders, but mine (Active 1.1) is a little storage box.
I can't put it in the glovebox as I need to be able to cradle my iPhone in the FM Transmitter (Belkin TuneBase).
Any help greatly appreciated!
Thanks.
Just got a trim adapter for where it should go on higher models and the power socket itself. The basic instructions say connect the plug into a live and a ground. Come someone give me help on this? Don't know where the best place to wire it is :)
Thanks.
Bump.
Has anyone got the wiring diagram for the Panda Active?
If possible I would like it as standard as possible, as the wiring loom is already there. Just need to work out where I can plug it in to. Battery means drilling thru etc.
Thanks so far :p
Bump :)
The mechanics at college had a look at it. The wiring in the centre console (under the blanking plate) is earthed, but not connected to a live. Does anyone know where the end of that wiring is? They jut couldn't find it!
Thanks,
Jonty
there has been a lot of talk of it not being connected to the fusebox... I'm hoping (as I want to do mine) that its just a case of missing a fuse/relay and not that I have to pull the thing to bits and get the crimping pliers out...
here is a picture of a 100hp fuse box (that I asked for a while ago on here) and my fusebox on the 1.1 Active Eco ... as you can see there are several things missing
