So the girlfriend got stranded tonight, on an uphill stretch of dual carriageway. Car ground to a halt with no power, and engine management light on.
Fair play to the breakdown service that she has free with Lloyds TSB, as the AA were with her within 10 minutes. AA diagnostic came up with suspect throttle position sensor , although she didnt get the actual fault code number :bang::bang:. The AA counldn't reset the fault so that might help int he long run.
Anyway car is back home, i've taken off the airbox, and been able to move the throttle butterfly by hand so at least its not jammed in its travel. I've taken the throttle body position sensor connection apart, there doesn't seem to be any corroded pins and connected / reconnected it a few times to clean contact surfaces.
Still got the light on, and the engine has a lumpy idle. Pressing the throttle will raise the revs to 1300rpm, still with a slight lumpiness - this might be enough to limp it to the local garage round the corner, but its not going to get to the Fiat dealer 26 miles away like this.
I know the throttle system is fly by wire, so the fault could be at the pedal end?.
Is there anything else i can physically check / do myself without any fault reader ???
Do i need to disconnect the battery for a few minutes to clear the existing faults ??
I could get another throttle body from a scrappy but it could be an expensive swap with no success ??
The car has done less than 70 miles since it was in the dealership for the ABS recall, so i wonder whether they've disturbed/ damaged the loom somehow when moving bits around the engine bay (although i can't see anything obvious hanging off !!)
