| | The sport button really does work! I've never really played with the sport button on my 100hp. I was driving home the other day on a flat road and decided to give it a press. Basicially you can feel the car speed up or slow down depending on which setting the car is on. You need half the throttle pressure to go the same speed as with not being in sport mode. I was quite surprised at the difference. Give it a try.
__________________ Ex Fiat coupe 20v turbo. | ||
Posts: 606 Thanks: 21 Trader Rating: 0 | Re: The sport button really does work! 'SPORT' mode had been a default mode ever since I got the car. It just feels so sluggish and unresponsive without it!
__________________ . ![]() | ||
| | #3 | ||
| | Re: The sport button really does work! Exactly that. I just never realised how much before.
| | #4 | ||
Posts: 2,166 Thanks: 36 Trader Rating: 0 Drives: | Re: The sport button really does work! Sport mode is the default setting on my car. I've never driven it more than five minutes with it off. Can't believe you haven't tried it much before.
__________________ 2008 Red Panda 100hp 1996 JDM Integra Type-R | ||
| | #5 | ||
Posts: 546 Thanks: 18 Trader Rating: 0 | Re: The sport button really does work! What sport button? ![]() Only time the sport button on mine gets turned off is in the summer, when for some strange reason now and again it turns itself off
__________________ New Orleans Blue Panda100hp Audi R8 Style LED Lights : LED Sidelights : Italian Pressed Metal Style Number Plates : Italian Flag Wing and Boot Badges : Silver Indicator Bulbs : Panda Aerial Topper | ||
| | #6 | ||
Posts: 2,166 Thanks: 36 Trader Rating: 0 Drives: | Re: The sport button really does work! Mine turns itself off occasionally, seemingly when I get the immobiliser light on the dash, happens once in a blue moon. That's the only time I have driven it with sport button off, which I tend to notice pretty quickly.
| | #7 | ||
Posts: 222 Thanks: 3 Trader Rating: 0 | Re: The sport button really does work! There is no reason whatsoever to NOT use the lovely Sport button...it doesnt even use more fuel,in fact it may even use less.
| | #8 | ||
Posts: 78 Thanks: 2 Trader Rating: 0 | Re: The sport button really does work! I almost never use my Sport button... in fact the last time I used it was at The Nurburgring last August. It's a p.i.t.a on the daily commute! | ||
| | #9 | ||
Posts: 945 Thanks: 64 Trader Rating: 0 | Re: The sport button really does work!
__________________ ![]() ....If you'd like a custom sig....Just ask me and then donate to FF! | ||
| | #10 | ||
Posts: 1,034 Thanks: 2 Trader Rating: 0 | Re: The sport button really does work! I think the sport button works in the same way that the gas pedal works. Pushing the sport button is like push the throttle down a bit further. At least I think that's how it works. The Sport button is like 'normal' IMHO, but with the non-sport mode I need to move my right foot too much.
| | #11 | ||
Posts: 488 Thanks: 7 Trader Rating: 0 Drives: | Re: The sport button really does work! Sport almost always on - off when putting car into/out of garage and on the very rare occasions when I'm in very slow-moving traffic - two or three times a year. Apart from the throttle response the steering weight - pseudo feel - is more natural as well.
| | #12 | |||||
Posts: 9 Thanks: 0 Trader Rating: 0 | Re: The sport button really does work!
Definately ON needs to be the default setting!
| | #13 | ||
| | Re: The sport button really does work! does it really remap to give a different response or is it exactly the same but you have to push the pedal further down to get that response. As I either potter or have throttle to floor I find the unsporty mode fine. Another factor for me is being very short I have the issue with the achy ankle at small throttle openings so potter mode which means bigger movements of throttle is a bit more comfortable.
__________________ ![]() 09 Yellow Panda 1.2 Dynamic 2005 C4 & 1997 ZX | ||
| | #14 | ||
Posts: 93 Thanks: 1 Trader Rating: 0 | Re: The sport button really does work!
__________________ | ||
| | #15 | ||
Posts: 78 Thanks: 2 Trader Rating: 0 | Re: The sport button really does work! i severely doubt it changes engine mapping at all. More likely is that it increases the % output of the throttle for any given position; making it more responsive at smaller throttle pedal inputs... Having software that mucks about with engine mapping is more complicated (and expensive) than having something if/then based that tells the engine to wind a few notches onto whatever your throttle input is. Similarly, the steering doesn't truly become sharper or more direct... the software will just tell the p/s system to wind off a certain % of assistance. That said though, there's something satisfying about just having a sport button in a Fiat Panda!! | ||
| | RobW | 500 | 18 | 01-01-2010 23:28 |
| | Juliet Bravo | Bravo | 46 | 15-11-2008 11:07 |
| | Jimrod | Panda | 29 | 10-10-2008 17:52 |
| | white 500 | 500 | 5 | 25-05-2008 18:45 |
| Nature's 'Sport' button | hpScot | Panda | 1 | 16-08-2007 23:00 |
