Hi all,
I was checking the fluids this weekend when i noted that the radiator seemed loose. If i grab the top hose and pull gently i get about 5-8mm of movement on the whole raditor at the right hand side ( as stood at the front facing the vehicle) the left hand side is relativley firm.
I have tried to find a loose bolt or screw as i assume its simply come loose but i cannot find the location anywhere.
It may be that the assembley is meant to move slightly but 5-8mm cannot be correct, my assumption is loose connection somewhere ?
Anyone a drawing or know where/how the raditior fixes into place.
The fan assembley is firmly in place before anyone asks, this is tight upto the rad so no moevement in that piece.
All advise welcome as usual.
