Not sure if you've found the real problem to this, but I've already been through two MAP sensors (max air pressure), and two MAF sensors (main air flow), all done at the recommendation of various Fiat Dealers. I've since had Simonstone of Bath tell me they know how to fix it, but that they'll not tell me what they'll do. - I now know why !
The turbo on the Multijet engine is a normal wastegate style turbo, not a variable vane type, and when we took ours off for a look see, the wastegate diaphragm actuator was stuck. We couldn't shift it with a pressure / vacuum tester, but with a little leverage with a pair of pliers it came free easily. - Note that on the car, the diaphragm rod angles upwards as well, which wouldn't help if you managed to get water lying on it.
Now I've got the Panda Multijet back working correctly, no more limp home mode cutting in as you go past 3000 rpm anymore.
Unfortunately you don't get the extra boost sub 3000rpm just before the MAP sensor shouted for help, and limp home mode kicked in. - Yes, not surprisingly, there was definitely more grunt than usual.
My question now is, how does the Electronic chipping of a Multijet give more power, if they do not adjust the wastegate settings ?? - I'd have thought you still needed to get more compressed air into the engine, i.e. higher boost, to go with any extra fuelling from an ECU mod ??
Oddly, the following day a Grande Punto came in with exactly the same problem, so all we did was pull the small rubber waste gate actuator pipe off the front of the inlet side of the turbo, which is easy to get to, and gave it a couple of puffs of compressed airline air pressure, and it freed it up for the guy ASAP.
I'm just wondering how many labour hours the dealer would have charged me for the 10 minutes work it really took <grin>.
