| | Fitting a aux power/cig lighter in the eco There are a few threads on this but Im looking for people who have fitted one, where they fitted it and what they wired it too. And any pics would be a help too as you really only get one chance at cutting a hole in the dash, lol I've taken the 180w aux socket from a multipla BTW Jim
__________________ ![]() | ||
Posts: 61 Thanks: 1 Trader Rating: 0 | Re: Fitting a aux power/cig lighter in the eco Good Thread...I want to know too
| | #3 | ||
| | Re: Fitting a aux power/cig lighter in the eco Jim, goes on center console. If anything like the Classic Panda's, wiring will already be there under blanking plate as they're a dealer fit option | ||
| | #4 | ||
| | Re: Fitting a aux power/cig lighter in the eco See, this is why I was looking people who have actually done it Jon as yes there is wiring but it's not connected to anything and the bits on the fuse box it should connect too are missing Really need an expert rather than general advice on this one ![]() That and I'm going to drill the glovebox or the bottom of the gearbox housing as where it is that fiat would put it infront of the handbrake is useless to charge a phone or a satnav with a short lead Jim
| | #5 | |||
As far as wiring it in Jim, I personally would remove glove box and tap a live feed direct from battery. That way it's always live and not ignition switched, and assuming there is a grommit in the bulkhead to take wire through, you won't need to drill a hole in the bulkhead. Another advantage of doing it that way is you don't have to fiddle with existing electrics, meaning you won't void any warrentiees in the even of other electrical gremlins occouring | |||
| | #6 | ||
Posts: 3,022 Thanks: 84 Trader Rating: 0 Drives: | Here you go Jim, here's the socket in Squirrile ![]() Just a suggestion, if you are looking at a higher/forward placed site for a socket is it worth putting it where the useless vent for Climate Control is ? Trev
__________________ See Fred's latest excursion ! http://www.fiatforum.com/leisure-lou...ml#post2432709 ![]() Last edited by udtrev; 03-07-2009 at 19:04. | ||
| | #7 | ||
| | Re: Fitting a aux power/cig lighter in the eco yeah, that is way too low for normal use... what where they thinking? That climate control vent just infront of the gearstick sounds promising thou ![]() Wonder how much space is behind it and how hard it is to get access too? Oh and Jon, Fiat really don't want you to play with their cars as there is no gromets thou the bulk head... See I've picked up all the 'downers' from the other threads but no successes yet ![]() Jim
| | #8 | ||
| | Re: Fitting a aux power/cig lighter in the eco There not one anywhere? How wiring get through? You able to trace / follow that | ||
| | #9 | ||
| | #10 | ||
| | Re: Fitting a aux power/cig lighter in the eco Could feed it around A pillar behind wing, and door trim like the garry boys do for their sub wiring from battery ![]() Commonly done on 206's | ||
| The following user says "Thank You!" to Most Easterly Pandas for this useful post: | ||
FredTheFiatBear (15-07-2009) | ||
| | #11 | ||
Posts: 3,022 Thanks: 84 Trader Rating: 0 Drives: | I have the CHEAP alternative, I have a 4 way adaptor that sits on the dash and I connect to that. Trev
__________________ See Fred's latest excursion ! http://www.fiatforum.com/leisure-lou...ml#post2432709 ![]() | ||
| | #12 | ||
| | Re: Fitting a aux power/cig lighter in the eco | ||
| | #13 | ||
Posts: 3,022 Thanks: 84 Trader Rating: 0 Drives: | It sure does Jon, ![]() The only problem I have with it is that the glue to stick it to anywhere is crap - a couple of days and it's back to rattling in the recess ![]() And before someone mentions it I am not forking out for a tube of tigerseal for a ruddy socket block Trev
| | #14 | ||
Posts: 61 Thanks: 1 Trader Rating: 0 | Re: Fitting a aux power/cig lighter in the eco what about those really sticky double sided spongey pads you can get.... they stick like s**t to a blanket
| | #15 | ||
Posts: 37 Thanks: 2 Trader Rating: 0 | Re: Fitting a aux power/cig lighter in the eco Well, as you can probably tell from this pic of me relaxing at the beach checking the satnav I got the power socket sorted in Jim's panda... Boy was it a pain getting thou all them nooks and crannies routing the wire was only something you could do if you were 6" tall and have no bones, just stuffing! When I'm back on full form I'll upload the pics of my work ![]() Fred
| | Alex-R | Punto | 13 | 07-07-2008 18:13 |
| | R12MUS | Punto | 11 | 16-03-2008 18:44 |
| Cig lighter | terrier | Ducato | 2 | 19-12-2007 20:46 |
| | clawliger | Cinquecento / Seicento | 6 | 27-04-2007 16:52 |
| | cinquechicken | Cinquecento / Seicento | 9 | 10-06-2004 03:30 |
