Posts: 2 Thanks: 0 Trader Rating: 0 | Front pads question Hi guys, I'm about to attempt for the first time a front brake pad change on my 2006 panda dynamic. ![]() Could anybody tell me if there is anything I should look out for, and also, does anybody know if the caliper is held on with a pin or bolts. If its like the old shape panda I had, it was a pin and you just swiveled the caliper upwards to remove the pads. Is the new one the same? Any help would be greatly appreciated!! Thanks, Josh
Posts: 115 Thanks: 2 Trader Rating: 0 | Re: Front pads question Not seen the old Panda calipers. But it sounds the same, just a pin, and caliper swivels upwards. Really easy job.
| | #3 | ||
Posts: 2 Thanks: 0 Trader Rating: 0 | Re: Front pads question Brilliant!! Thank you very much for your help!! Hopefully it should be an easy job.
| | #4 | ||
Posts: 810 Thanks: 80 Trader Rating: 0 | Re: Front pads question On mine it was a bolt, not a pin. Unscrew the lower bolt and the caliper swings up as you describe. There should be a new bolt, pre-painted with locking compound, supplied with the pads to be used on reassembly. Pete
__________________ 2005 Panda 1.2 4x4 :: 2001 Multipla JTD ELX :: North Herts :: Remember, if you find a post helpful, press the Thumbs Up button to say 'thanks' | ||
| | #5 | ||
Posts: 115 Thanks: 2 Trader Rating: 0 | Re: Front pads question My 06 Dynamic was definately a pin, it needed driving out and was retained by small spring clip. There must be more than one variation?
| | #6 | ||
Posts: 1,176 Thanks: 41 Trader Rating: 0 | Re: Front pads question The 4x4 and diesels with their ventilated front discs seem to have a different set up from the other models with non-ventilated discs.
| | #7 | ||
Posts: 134 Thanks: 3 Trader Rating: 0 Drives: | Re: Front pads question What about the bottom if the range the 1.1?? Is that Bolt or clip??
| | #8 | ||
Posts: 13,259 Thanks: 210 Trader Rating: 0 Drives: | Pin with clip holding that in same as the 1.2..also used on cento's and early puntos..
__________________ International man of mystery ![]() Wit ..sarcasm you get it all from me.. | ||
| | #9 | ||
Posts: 1,176 Thanks: 41 Trader Rating: 0 | Re: Front pads question Watch that little clip, it's a bugger if it pings off and disappears, from my experience of a Cinquecento.
| | #10 | ||
| | #11 | ||
Posts: 3,743 Thanks: 128 Trader Rating: 2 | Re: Front pads question
__________________ Wanted : Nothing at the moment | ||
| | wst62 | Grande Punto | 25 | 02-02-2009 21:27 |
| | numero-uno | Stilo | 7 | 23-06-2007 15:21 |
| | Werner | Punto | 10 | 20-04-2007 16:20 |
| Front pads | ian grant | Panda (Classic) | 2 | 03-12-2005 22:08 |
| | David M | Punto | 6 | 04-11-2005 18:50 |
