The FIAT ForumThe FIAT Forum is in no way affiliated with or endorsed by FIAT S.p.A.
Forge Motorsport
Go Back   The FIAT Forum > FIAT Cars > Panda
Old 23-06-2009   #1
Rapid old fart
jakelleo has donated!
Question 100HP Rear anti roll bar
I wonder if anyone is or has attempted to fit the Ford KA arb ?
I previously had a Skoda Fabia Vrs and had a arb fitted and it made such a difference to the general feel and handling that its got to be worth consideriing on the 100HP.
The rear suspension is very similar in general with both chassis configurations.
Its got to be worth a thought or two. I didnt even have to alter the
springs or dampers on the Skoda. It was just a simple bolt on application.
jakelleo is offline
Old 23-06-2009   #2
Re: 100HP Rear anti roll bar
It's certainly worth investigating.
I think the biggest difference between the two cars is that the Fabia is very softly sprung as standard so the ARB is quite effective at "tightening up" the handling. Whereas the 100hp is very stiffly sprung as standard so an ARB may be counter productive without going down the route of making the springs softer.
Of course, I'm an armchair mechanic so probably wrong
Chris
Holding up the traffic in a little Italian.........
ScoobyChris is offline
Old 23-06-2009   #3
Most modern front drive hatchbacks are set up for understeer which i guess can be remedied by tightening up the rear roll. I am guessing it will make the rear far more twitchy in on the limit situations though.
55reg Panda Sporting, Black with stripes.
ivantate is offline
Old 23-06-2009   #4
HP. has donated!
It would probably help as part of a rethought suspension package - i.e. differently rated springs, shocks and the bar.
Pete.
HP. is offline
Old 25-06-2009   #5
Lauren
trackdayqueen's Avatar
trackdayqueen has donated!
Agreed. You'd need to revise the dampers and springs to work properly with an ARB.
If you just put an ARB on with the stock setup reckon it'd make for some interesting handling, might even be more oversteery than my integra!
2008 Red Panda 100hp
1996 JDM Integra Type-R
trackdayqueen is offline
Old 26-06-2009   #6
Rapid old fart
Talking Re: 100HP Rear anti roll bar
I can only relate from expeirence..
Would point out the Vrs version of the Skoda Fabia was the equal of the 100HP in as much as the suspension was lower and the dampers were of a more agressive nature than the standard Fabia but with more power in fact a minimum of 130bhp and 310 Nm ( and in my case 180 bhp and 350 Nm) proved that the rear anti roll bar that I and many other Vrs owners fitted made such a difference I could not help but bring it to the attention of Panda 100HP owners who must admit the handling could do with a bit of tlc..
I think that the cost of trying this arb from the Ford parts bit must be worth a punt.
I would love to do it but, I live in a small central London flat with no garage to play around in.
jakelleo is offline
Old 26-06-2009   #7
But the Fabia's suspension was still rolly-polly compared to the rock hard suspension in the Panda
Chris
Old 26-06-2009   #8
Lauren
Reckon you'd have to change the whole rear torsion beam though, plus you'd have to guess spring and damper rates which may or may not be successful.
I don't think it's just a case of bolting one on.
Old 29-06-2009   #9
Smile Re: 100HP Rear anti roll bar
Hi all firstly I don't (yet) own a Panda 100hp, but my wife has a Panda MJ and I have an Alfa 145 Cloverleaf so hopefully I qualify to post! I have been doing a bit of research on the Panda 100hp's notoriously stiff suspension with a view to buying one - alas no dealer within 30 miles of me has a 100hp to test drive...aaargh! However I do know a bit about suspension and also work for Ford as an engineer. To clear up a common misconception the rear suspension on all Pandas has a built in anti-roll bar, that's the twist beam bit. Thing is they use the same beam for all Pandas (except the 4x4 according to another post on the forum) so what's stiff enough for a 1.1 is not going to cut it on the 100hp. The rear end of any FWD car needs to stiff to work all the tyres evenly (except the inside rear which can happily be off the ground during hard cornering as per quick renault clios).
So the choice is to either add a supplementary rear arb (like Ford did on the new Ka, or Abarth on it's 500) or use stiff springs / long bump stops which Fiat did on the 100hp. Maybe it was driven by cost, but maybe it drives better (better turn-in perhaps?) using the stiff spring option, we may never know.
However I looked under a new Ford Ka the other day and I'm pretty sure the beam is the same as Fiat use, and the ARB just sits inside it and bolts (I think) to the shock bottom mounts, so if anyones interested I can find the Ford part number for the additional ARB, rear springs, dampers and bump stops (they will all need to be fitted together) and somebody can try! It will definitely cure the ride but may lose something of tha handling magic the 100hp has become famous for.
Incidentally I have driven the new Ka, and found it quite underwhelming in the handling department. My wife's Panda MJ does roll around slow corners a bit but is much more fun to hustle on a country lane (pretty darn good actually) than the Ka, and remember I work for Ford so I'm not biased!
Oh yeah and my Alfa 145 has the same stiff springing and uber long bump stops at the rear as the 100hp, and also handles a treat but rides quite badly. I found the rear shocks were underdamped and using koni's or KYB ultra's helped the ride (less bouncy). Eibachs also helped hugely due to being a progressive spring on the back, but ruined the handling at anything other than 9/10ths and the front became annoyingly crashy due to lack of wheel travel.
So there's my two pence worth, I'll get back to my (ahem) very busy day at Ford Motor Company
claude10000000 is offline
Old 29-06-2009   #10
Brilliant - very useful and not speculative as most of the posts have been (necessarily).
4x4 rear totally different, of course; yes the beam acts as an ARB on a torsion beam setup; does suggest that lack of damping on rebound is an important contributor to any shortcomings.
babbo umbro is offline
Old 29-06-2009   #11
Having said all that I'm still itching to test drive the 100hp - I live in NE London so hardly in the middle of nowhere, but not one single dealer has a 100hp in stock!
Does anybody in the area fancies driving my 145 in return for a quick drive in the 100hp? Even as a passenger ride, as my main concern is the (lack of) ride comfort particularly for my 1 year old son who will be in the back!
Old 29-06-2009   #12
You're welcome to drive mine, but I suspect dealers will be closer
In terms of ride, I've been in the back when it's being driven in a spirited fashion, and my 3 year old daughter also regularly rides in the back and I don't think it's that bad at all. It's only if you continually drive across pot holes or try and fly over speed bumps that you'll be experiencing any crashiness imho.
My daughter loves it btw, and can happily fall asleep if it's a long journey
Chris
Old 29-06-2009   #13
There's no getting away from it - the 100HP's suspension is very firm. On the other hand I'd sooner that than something too floaty; we went to Italy and back at Easter and the car acquitted itself very well - it did have a wood burning stove in the boot on the way and about 100 litres of wine and sundry other delicacies on the way back to settle it down. The back seat puts passengers quiet high and spirited cornering can roll them round a bit but a child in a safety seat would be better off than a tall adult. The roads in Devon are pretty bumpy but I've never felt that the 100HP was uncomfortable.
And it does stick like ---- to a blanket.
Old 29-06-2009   #14
laverda has donated!
Denmark
Hi Claude
Good writing you came up with.
Maybe you can take some good pictures from the Ka's ARB. underneath and put them up here ?
laverda is offline
Old 29-06-2009   #15
Chris
Thanks for the replies, sleeping children are essential for a relaxing car journey . Firm suspesnion I don't mind and I'm used to slowing down for speed bumps due to the lowered Alfa! As long as it's not crashy or causing excessive high speed cheek wobble in my son I'll be happy with the tradeoff of good handling the 5 days a week when it's just me in it. Still I won't buy without a test drive so the quest continues.
Meanwhile I'll try and get some pics of the Ka ARB and post them.
(T) rear anti roll bar Platoon Uno 26 24-06-2009 08:03
(T) Anti roll bar... pandamonius_maximus Panda (Classic) 33 20-03-2009 11:58
(G) My Uno project - Rear anti roll bar jjhepburn Uno 14 02-03-2007 06:16
(G) Anti-Roll bar mod's, thicker, rear one? faster4_tec Punto 9 10-11-2006 23:09
(G) anti-roll bar jj la bomb abarth Cinquecento / Seicento 8 19-04-2006 17:44
Copyright ©2002 - 2010 FIAT Forum
