| | #16 | ||
Posts: 2,172 Thanks: 36 Trader Rating: 0 Drives: | Re: 100HP Rear anti roll bar Claude, the weird thing about the 100hp is that it tends to lift an inside front wheel on cornering, which obviously have some fairly serious drawbacks. This seems to come about by the rear not being stiff enough, or put another way roll control not being enough at the rear. Or it could be due to a lack of travel at the front (but that is unlikely). I think if it's a bolt on option and the cost is reasonable, it would be worth a try but the rear suspender settings would need some revision.
__________________ 2008 Red Panda 100hp 1996 JDM Integra Type-R | ||
| | #17 | ||
| Rapid old fart Join Date: Apr 2009 Location: S.LONDON
Posts: 65 Thanks: 1 Trader Rating: 0 | To add to the story.. One of my earlier cars (and have had many) was a 1955 Volkswgan beetle, that had a very wayward front end being tail heavy. It was common to add sand to the front boot space. Being a bit light with the cash in those days managed to acquire 100lb bag of cement,it might have even been 2 bags, which were placed in the spare wheel space. But due to water ingress the cement went a bit hard . But the handling improved no end. When sold on even managed to get a good part exchange, the garage didnt check the boot before the exchange, but they were very impressed with the handling. Wonder if a couple of bags of dry cement in the boot of the 100hp would help. Its only a suggestion, am really trying to be helpful.. Jake.
| | #18 | |||||
Posts: 488 Thanks: 7 Trader Rating: 0 Drives: | Re: 100HP Rear anti roll bar
| | #19 | ||
Posts: 9,262 Thanks: 75 Trader Rating: 0 | Re: 100HP Rear anti roll bar Just out of interest, has anyone seen just how little movement there is on the rear of the 100hp before it hits the bump stop?
__________________ Pete. | ||
| | #20 | ||
Posts: 244 Thanks: 8 Trader Rating: 0 Drives: | Re: 100HP Rear anti roll bar Just read in autocar that the 500C has gained a rear anti-roll bar and all 500's moving forward will get one. Supposed to improve the ride so I wonder if this actually is something the 100HP would benefit from?
__________________ What happens in Aldershot stays in Aldershot..... | ||
| | #21 | |||||
Posts: 65 Thanks: 1 Trader Rating: 0 | Re: 100HP Rear anti roll bar
Whos going to give it a go ?.. I would love to, but just dont have a garage to fit it.. Probably just a bolt on, same as the Skoda Fabia item.. Jake.
| | #22 | ||
Posts: 668 Thanks: 29 Trader Rating: 0 | Re: 100HP Rear anti roll bar You have to love the 100HP. I was moving along on the A303 yesterday and I'll swear at least 2 or more wheels left the ground. I could see a sort of double undulation coming up so I just gripped the wheel and waited to see what would happen. Must have looked hilarious from behind.
__________________ ![]() Red Pandamonium 100hp / White Pop | ||
| | #23 | ||
| happy 100 Join Date: Sep 2007 Location: Sudbury
Posts: 37 Thanks: 0 Trader Rating: 0 | Re: 100HP Rear anti roll bar Claude, I,m in suffolk (just) if you haven't yet managed a test in a 100hp, welcome to have a go if you wish. John B
| | #24 | |||
Posts: 6,889 Thanks: 260 Trader Rating: 0 Drives: | Re: 100HP Rear anti roll bar | |||
| | #25 | ||
Posts: 488 Thanks: 7 Trader Rating: 0 Drives: | Re: 100HP Rear anti roll bar OK. Can anyone come up with the following part numbers, please? 500 1.4 rear spring 500 1.4 rear shock absorber 100HP rear spring 100HP rear shock absorber 500 1.4 torsion beam (also if different fro other 500s) 100HP torsion beam (also useful to know if different from other Pandas) These to establish commonality. Then 500C torsion beam 500C anti-roll bar - if separate from torsion beam 500 Abarth torsion beam 500 Abarth arb 500 Abarth rear springs 500 Abarth rear shockers With that info it should be possible to work out what could be slotted in to 100HP with minimum hassle to give softer rear with arb and with sensible ride height.
| | #26 | |||
| | #27 | |||||
| | #29 | |||
Until anyone finds out for sure we're merely just speculating. | |||
| | #30 | ||
| | Platoon | Uno | 26 | 24-06-2009 08:03 |
| | pandamonius_maximus | Panda (Classic) | 33 | 20-03-2009 11:58 |
| | jjhepburn | Uno | 14 | 02-03-2007 06:16 |
| | faster4_tec | Punto | 9 | 10-11-2006 23:09 |
| | jj la bomb abarth | Cinquecento / Seicento | 8 | 19-04-2006 17:44 |
