- Mar 26, 2011
- 158
- 36
toe parallel camber-1
could be ovals hard to tell from angle of pic
whats in the bags, i cant see helper springs or rear adjusters in the photo
Other option is pillowball top mounts, depends how much you want to spend really.
I very much doubt that there's anything out there for the Panda.Tis a weird setup as it looks like you can adjust castor but nothing else on the stock ones.
I guess you'd need to identify if there is anything out there.
All depends upon how much negative camber you want. Surely for the road you aren't going to be looking for more than 1.5 deg neg?
Toe makes a difference to turn in. Try lessening the toe, try running it parallel, given the 500's relatively good stability (though short-ish) wheelbase it ought to be fine. I guess it depends upon how much you want to really try and lessen the understeer.
Tbh I'd just go to Demon Tweeks and say give me a nice setup which isn't going to kill tyres.Well, more toe is going to increase understeer and I'm sure you'll agree it's bad enough for that already.
Maybe just lessen it a bit, run minimal toe-in.
I think that's fine. If I pay to get my geo done, though I tend to go with a list of what settings I want, but as you say you don't want anything too mad. In all honesty if the car was setup bang on the OEM settings rather than within a mile or two as per the manual, then I'll bet it will transform the car. Never seen such wide tolerances as there were on the Panda.
result: huge smile on my face after panda is restored to original crispness after fitting koni/eibach then camber bolts-toe parallel and -1 camber. handling is amazing feels very 'sure footed' again even at speed/cornering. well worth every penny and the suspension has removed the 'pogo' totally. its amusing to watch everyone else brake at roundabouts and know i dont need to! lol. Big shout out to randysbits for all his help regarding this issue-thats one of the things ive found about the fiat forum here and in person at brooklands-very friendly bunch of peeps.
Good to hear ! how much have you turned the dampers by ? a quarter ?? or are you still bedding in at the moment ???result: huge smile on my face after panda is restored to original crispness after fitting koni/eibach then camber bolts-toe parallel and -1 camber. handling is amazing feels very 'sure footed' again even at speed/cornering. well worth every penny and the suspension has removed the 'pogo' totally. its amusing to watch everyone else brake at roundabouts and know i dont need to! lol. Big shout out to randysbits for all his help regarding this issue-thats one of the things ive found about the fiat forum here and in person at brooklands-very friendly bunch of peeps.
Just saw this thread.
The camber you have is less than I run on my Clio, I run 2° negative camber, and to achieve this I fitted Eibach camber bolts from Venom Motorsport which was cheapest I found at about £22 delivered.
To buy the correct bolts you need to go down a size, for example the Clio uses 14mm bolts, so you use a 12mm camber bolt. It is in effect a 12mm bolt with a cam on it that when fitted in the top strut hole and then rotated moves the strut in and out to the desired camber setting.
Clio also runs 1° 30mins degrees negative standard at the rear.
I also run Eibach camber bolts on front our Civic type-r, with about 1°30mins negative, same rear using adjustable top arms.
Our FTO has Cusco coil-overs with adjustable top mounts, and again runs 2° negative at front and using the standard fully adjustable multi-link rear suspension set to 1°30mins.
All our cars run 10mins tow out at front, and all get even tyre wear.
It's toe out that will destroy the inside of tyres, and too much toe in that gets the outside edge. Unless running over 2° camber, will have little effect on wear rates.
The Panda if like the 500, uses a very small 10mm bolt on the struts, and therefore you need to run an 8mm camber bolt, which goes against what you think should be fitted to hold the damper in place, but I know one guy with a 500 Abarth running Gaz suspension has fitted camber bolts now over a year with no problems.
Even the 500Trofeo race cars used an adjustable shim on the damper to increase camber as the top mount design doesn't allow it even with the Abarth produced solid top mounts. The Clio is like this and apart from the Dutch made AST top mounts that Maxi put up which can be rotated so you get castor change as well as camber, the bolts are only way forward apart from old school way of slotting the holes, getting required setting, welding on a washer so that when ever they come off can be refitted in same position.
