Old 26-03-2009   #1
kipster1 has donated!
Heater blower only working on setting 4.
As title, anybody have any ideas please?
Setting 1,2,3, no longer work,
kipster1 is offline Reply With Quote Quote
Old 26-03-2009   #2
Re: Heater blower only working on setting 4.
It may be that your fan bearings require cleaning/lubrication. Its possible that only setting 4 gives enough power to make fan actually turn.
There was a recent thread with similar issue on this forum.
2012 - Toyota Auris Hybrid 1.8 T-Spirit
2008 - Fiat Panda Multijet 1.3 Dynamic
- R.I.P.
Ingvarr is offline Reply With Quote Quote
Old 26-03-2009   #3
Another possibility is the heater resistor pack has failed (which will likely be by-passed on position 4)....
Chris
Holding up the traffic in a little Italian.........
ScoobyChris is offline Reply With Quote Quote
Old 26-03-2009   #4
Yellow is the way to go!
Wee Smurf's Avatar
Wee Smurf has donated!
Tritryst Champion, Retro Pairs Champion, Retro Pairs 2 Champion
Quote Originally Posted by ScoobyChris View Post
Chris
I'd say it was the resistor. Resistor failed and was replaced so many times on my old Polo. Strangely it's gone again, so another trip to the scrappy required.
The Northern Ireland Italian Motor Club. Find us at: http://www.niimc.net.
We meet on the first Tuesday of the month at the Premier Inn (near Sprucefield roundabout) at 7:45pm.
Note return to this venue please!
Come along - All Italian motors welcome. PM me for more details.
Wee Smurf is offline Reply With Quote Quote
Old 26-03-2009   #5
sdb-punto's evil twin
1383matt's Avatar
1383matt has donated!
if its like a punto,then resistor gone. my resistor went and i got a new one direct from fiat for £12
1383matt is offline Reply With Quote Quote
Old 26-03-2009   #6
I bypassed the resistor altogether on an old M reg Punto just out of curiousity - it was obviously burnt out - and the fan resumed working properly on all speeds, so how did that work?
Trimdoner is offline Reply With Quote Quote
Old 26-03-2009   #7
Thanks for the help, where do i find the resistor pack??
Old 27-03-2009   #8
Thanks for help so far, but can anyone point me in the direction of where the resistor block is?
Thanks.
Old 28-03-2009   #9
Ooooops!
Sorry for double post above, too much beer last night .
Cant remember posting first time!
Is this the resistor pack ? Thanks in advance.
Old 28-03-2009   #10
Almost identical to the M reg Punto. The little resistor on the end was the bit burnt out on that - I relaced it with a bit of fuse wire.
Old 28-03-2009   #11
I will have a closer look.
Thanks.
Old 29-03-2009   #12
The little component that sits on the top of the green block is a 'thermal fuse' rather than another resistor. If the whole green unit gets too hot, this 'fuse' fails (by melting inside)... which is why, Trimdoner, it worked on all speeds once you'd bypassed it. However, note that 'next time' you have no thermal overload protection so something else will burn instead!
Pete
2005 Panda 1.2 4x4 :: Multipla now sold... :: North Herts :: Remember, if you find a post helpful, press the smiley face 'thanks' button below
Herts Hillhopper is offline Reply With Quote Quote
Old 29-03-2009   #13
Quote Quote:
At least I know now not to do it on my own car
It was a couple of years ago on an old Punto my daughter bought - it's long since gone, scrapped after failing its MOT on too many things. Luckily it didn't catch fire before it went!
Old 04-09-2010   #14
Serbia
Quote Originally Posted by Herts Hillhopper View Post
Pete
Do you know the temperature for that thermal fuse on Punto (MK2)? Is it 216 degrees or some other (maybe part number if you have it)?
Thanks in advance
vladamar is offline Reply With Quote Quote
Old 04-09-2010   #15
You will probably have the temperature printed on the body, but it will be hard to read if it has 'burnt'. Try cleaning it with water first, followed by a very light abrasive eg toothpaste. You should then be able to read it!
Spares can be had from Maplin
http://www.maplin.co.uk/Module.aspx?ModuleNo=470
at the princely sum of 79p !
However you will have to fit the new one without overheating by soldering. If you can leave enough of the old legs use connectors from a a 1A chocalate block.
IIRC in my Picasso the old one was 144degC and I replaced with 152 degC. But in that car the resister pack is in the airflow of the fan so ifor yours it maybe a higher/lower value .
pmh is offline Reply With Quote Quote
heater blower control not working wiganlad Newbie Central 2 21-04-2010 12:39
(T) heater blower switch not working ...help me plzz djmacca Punto (Mk2/2b) 5 22-03-2008 19:47
My heater blower aint working voodoo55 Newbie Central 2 12-11-2006 23:09
(G) Heater Only Working On 1 Setting. fiatbravaross Bravo / Brava 5 23-12-2005 17:33
(T) Heater blower not working craig20vturbo Coupe 3 19-12-2005 20:40
