The FIAT ForumThe FIAT Forum is in no way affiliated with or endorsed by FIAT S.p.A.
Go Back   The FIAT Forum > FIAT Cars > Panda
Old 01-07-2009   #61
Re: multijet mpg
Originally Posted by KozmoNaut View Post
Those are the hydraulic lifters ticking because the oil is not yet at operating temperature and therefore a bit more viscous than ideal. It's nothing to worry about, all engines with hydraulic lifters do this.
I think this comes from the way most people think diesels should be driven, never venturing above 2000rpm and certainly never ever above 2500rpm!
"Ye gods, it would probably fall apart spinning that fast!" seems to be the general idea, I've even seen people drive like this in petrol cars
You can certainly cruise along at 50kph in 4th, but accelerating away will be rather slow until you hit the beginning of the powerband around 2000rpm.
I generally drive around between 2000 and 2500rpm at which point flooring it definitely produces results. For most driving, letting it get to ~3000rpm before upshifting is more than adequate, but if I really need to move, 4000 is the target. For extended acceleration as fast as possible on short onramps etc., 4500rpm is in fact the ideal shifting point, since that will put you right in the powerband in the next gear.
There is some turbo lag, true. I can take off smoothly by just releasing the clutch in 1st, but then I'll be below 1000rpm making very little power until I get further up the revs. It's a valid way to drive it, it's just very slow. Just slip the clutch like you would on a petrol car and don't hang around in the low revs for too long.
When driving around, don't baby it, let it have some revs and keep that turbo on the boil and you will make better progress, and dare I say possibly even better in-gear rolling acceleration in the Multijet Panda than in the 100HP From 2300rpm or so in 2nd or 3rd it really flies when you floor it.
Agree absolutely with what you say about the MJ - the power band is relatively narrow but from 2250 to 4500 rpm it pulls quite strongly - you need to anticipate the need to drop a gear or two and then it bowls alomg quite sweetly. But I can't agree with the comment relative to the 100HP - if you apply the same criteria about keeping in the sweet part of the torque curve, the 100HP is much quicker - I know the MJ has a relatively meaty maximum torque figure, but remember that the torque at the wheels is the torque at the flywheel multiplied by the gear ratio.
babbo umbro is offline
Old 01-07-2009   #62
Re: multijet mpg
I've never understood the concept of "in-gear rolling acceleration". Ultimately, you're saying that in a gear (of the gearbox designed for the car it's in) with the engine revs around maximum torque, the car really flies. I think the same would apply to the 100HP too?
Chris
Holding up the traffic in a little Italian.........
ScoobyChris is offline
Old 01-07-2009   #63
Denmark
Re: multijet mpg
Chris
What I mean is that normal "driving around" RPMs in a diesel are much better situated in the powerband compared to a petrol-engined car.
I know the official Fiat docs say the torque peak for the Multijet is at 1500rpm, my butt dyno says its around 2000rpm, in any case it's much lower in the rev range than on the 100HP.
Unless of course you drive the 100HP around at 4250rpm all day? (I would)
The 100HP really requires you to drop a gear or even two for good acceleration, a diesel has the power right where you are in the revband already. It's just more practical for day-to-day driving.
Heck, a Skoda Fabia vRS will out-accelerate a BMW 330i in the 80-120kph sprint, even with both cars right in their powerband.
KozmoNaut is offline
Old 01-07-2009   #64
HP. has donated!
Re: multijet mpg
Re: the hydraulic tappets - maybe for a second when cold, but even non-hydraulic tappetted Diesels generally sound like a bag of hammers when cold. Some of the posher makes like Merc seem to have minimised it a bit, but they still sound like farm machinery to a petrolhead.
I can see where you're coming from with the day to day driving comment, but would counter it with this: When you need to go in a 100hp, at 1,200 revs it won't. Neither will the multijet. The 1.4 picks up at around 2500, much like the Diesel, but the HP has another 4,500 revs to play with after that point as opposed to 2,000 for the Diesel - so it's actually a lot more flexible....
4250rpm all day in the 100hp? That's about 95ish mph in 6th, which isn't a problem!
Pete.
HP. is offline
Old 01-07-2009   #65
Re: multijet mpg
I assume you're talking about famous "in gear" time quote where both cars are in 4th gear? Having driven both, I can safely say that with each car in their optimium gear for that speed, the vRS won't stand a chance
The 100hp actually feels quite torquey, presumably because of the close gearing, and I've found as a result you don't always need to change down to accelerate briskly...
Chris
Old 01-07-2009   #66
Denmark
Re: multijet mpg
The Multijet is geared taller than the 1.4, though, so even though the revrange is shorter, it covers roughly the same range of speeds. The 1.4 revs much higher, yet the top speeds are pretty close to each other, the 100HP's higher top speed being somewhat down to the 6-speed box as well.
A Multijet geared like the 1.4 would have a really low top speed, but the 1.4 geared like a Multijet would have a really high (theoretical) top speed for exactly this reason.
And I spin ~3500rpm in 5th at 145kph in the Multijet, but that doesn't mean I drive around like that constantly when I'm off the motorway
I do however drive around at ~2000rpm almost everywhere I go that's not a motorway.
All I know is that no reasonable petrol-engined cars (ie. no 5-liter V8 musclecars etc.) have been able to give me the same rush of torque as a good diesel, apart from turbocharged petrols. And boy do they suffer on the fuel economy side of things.
Old 01-07-2009   #67
Lauren
trackdayqueen's Avatar
trackdayqueen has donated!
Re: multijet mpg
I thrashed the arse off my MJ as it was the only way to make any progress at all. I never babied it in any way. There is loads of turbo lag. The power band is too narrow.
If you pull away as described which is what I tended to do as I don't do clutch slipping you find that flooring it achieves nothing until you are way out into the middle of the road, then it all comes at once. It doesn't ever fly, not at all. It has reasonable acceleration if you catch it right, but select the next gear and it has to build boost again.
It's no way quicker than a 100hp (i've had both) because in the 100hp you have throttle response (which is absent in the MJ) so you can drop a gear or two and easily outrun an MJ. Sure the MJ might be quicker in in gear acceleration at some points but don't forget you aren't comparing like with like as the 100hp has a six speed box.
Honestly 30mph in 4th gear I just found a pointless exercise as there is just zero acceleration at that engine speed, it was embarrasing at times and frustrating at others.
I don't wish to offend anyone, but I thought the engine was absolute rubbish, it's too small for a dismal and it's too peaky and way too laggy. I just wanted to drive it off a cliff in the end. That's why I took a 1K hit on the finance to get rid of it and chopped it in for a 100hp.
2008 Red Panda 100hp
1996 JDM Integra Type-R
trackdayqueen is offline
Old 01-07-2009   #68
Re: multijet mpg
I honestly think you're being a bit harsh on the MJ. The engine is decently smooth for a diesel and a petrol-engined car offering the same performance would use more fuel. Driving it does call for a greater degree of anticipation because of that narrow rev band, though I have had a Tipo 1.9 Tds (not that tedious) and an Uno Turbo ie and I'd say the MJ's turbo lag is quite acceptable. I actually find driving the MJ quite satisfying as it calls for a little more concentration on traffic and road conditions - you have to anticipate and select a lower gear before you really need to - if you see what I mean - so I do sometimes find that I've dropped a gear or two only to find the need for it doesn't arise. I suppose it's a bit like a throwback to driving a (real) 500 where maintaining momentum became a primary consideration. We're taking the MJ to Italy some time in the near future to draw a direct comparison with doing the trip in the 100HP.
In the MJ, right on the peak of its torque curve, I occasionally think that it might be comparable to the 100HP over a narrow speed range - then I get in the 100HP and realise that it really is much quicker. I should say that I've done something over 8,000 miles in the 100HP and it still feels as though it's loosening up further.
Old 01-07-2009   #69
Re: multijet mpg
The diesel is great providing it is used correctly and most of the larger cars with similar MPG figures wont get near it for running around economy due to accelerating the extra mass and taking longer to heat up.
Anything over 70 starts to take its toll but there is a point where you have to use some power. Ours can sit and 85-90mph quite happily (happier than 65 on the hills) and still return good figures aswell as getting 62-65mpg on the girlfriends 10mile A-road commute.
Absolutely spot on for what we need. In reality the petrol 1200 would be just as good most the time as even on most long trips we sit at 70ish.
It was bought to be cheap, fun transport so works out perfectly. If I want speed I get onto 2 wheels.
As a comparison our 1100 Seicento, which was an Abarth with the low gearing managed 42-45mpg. It was great fun to drive and didnt have an economy readout on the dash though which might account for some extra fuel. (she was using it most the time and doesnt want to thrash about anyway.)
The more interesting thing is the long term costs as there are far more sensors/pumps etc on the diesel which will not come cheaply. then a headgasket or 2 and a cambelt change on the 1200 doesnt either.
As I have said before a Panda diesel with the 100hp running gear and 6sp box and the Lancia Ypsilon 105bhp 1300 multijet would be interesting if slightly laggy.
55reg Panda Sporting, Black with stripes.
ivantate is offline
Old 01-07-2009   #70
Lauren
Re: multijet mpg
Maybe you are right. Maybe i'm being a bit harsh on it, but I absolutely hated it. I have never had a diesel car before and I'm seriously put off ever owning one again as a result of my experience with the MJ. I don't mind anticipating road conditions and all that, but I like a car to be responsive and this is where the MJ really suffered for me. Maybe as you say all diesels are a bit like that. If that is the case i'll never buy one as I just find it completely goes against how I like to drive.
I like engines that you can really rev, hence owning the integra R, that sure likes to rev, ditto Mk1 MR2s and even my old E36 325i was surprisingly revvy. Obviously the 100hp does the job in that respect and I really do like it. Looking back I should have just bought the 100hp in the first place, I just was trying to be sensible at the time. /lesson learnt!
I respect that there are some who really love their MJ and there is nothing wrong with that, different folks, different strokes really.
It just didn't work for me.
Offical Fiat MPG, and your best MPG Most Easterly Pandas Panda (Classic) 19 11-07-2008 10:19
(G) Multijet MPG Trimdoner Panda 67 14-05-2008 00:08
(G) Panda 4X4 Multijet MPG... stephenbeetleman Panda 5 01-05-2008 22:12
(G) Grande Punto 1.3 Multijet [75Bhp] Mpg Trekfan Grande Punto 4 11-03-2008 11:37
Multijet MPG Highlander Panda 44 18-01-2007 08:11
Copyright ©2002 - 2010 FIAT Forum
