doblo
Member
A simple question. How do you change the rear wiper blade?
Two answers: buy a dedicated new blade (basically whole new arm) from Fiat, or on ebay...
Or, replace the front wiper blade, then slide the rubber part (and its two shiny metal strengtheners) out of the rear wiper arm (it will come out at one end if you bend it slightly), trim the old front blade to length (cut from both ends to use the 'good' part from the middle), and refit. Worked a treat for me. (Note the metal strengtheners are slightly curved -- make sure they go the right way, curving away from the screen otherwise the wiper only touches in the middle)
Pete
Pete
Pete
Spray with WD 40 and leave overnight, try again the next day.
I think that was aimed at the post re the stuck arm after removing the nut.Que?
I need to replace my wiper arm and having removed the nut the arm refuses to budge and I am afraid of applying too much pressure in case the back window cracks.
Could those who have done this before offer any advice or guidance as to how to go about getting the arm to budge?
I think all of these go together .Que?
