Frustrated Fiat Fool
- Jun 8, 2008
- 10
- 2
As part of the Annual D.I.Y. Service on my wife's Panda today I changed the Spark Plugs this morning. Drove the car round the block and all seemed to be fine... or at least that's what i initially thought.
Started the vehicle this afternoon to fill it up with petrol to be greeted by a "ping" and the words "Engine Failure" on the dashboard... fantastic!
The engine also seemed to be misfiring.
I returned the "old" spark plugs back into the engine, just in case the brain of britain from halfords had supplied me with the wrong spark plugs. This made no difference. Rather than mess about any further, i called out the R.A.C.
They turned up promptly, i confirmed that i had definetly not tinkered with any of the injectors. He connected a lap-top to the ECU that stated "Injector No 4 Failure". The R.A.C. guy then wanted to prove this was the case by:
1) Checking the Coil.
2) Checking all 4 injectors with a flashing bulb connector.
3) Swapping round leads.
4) Disconnecting Injector 4 whilst keeping the engine running which had no effect what so ever.
Conclusion:
Injector No 4 Failure confirmed - Car Towed away to a "recommended" Non-Fiat garage for repairs.
Questions:
1) Do Fiat keep this part in stock?
2) Any ideas of how much it will cost?
3) Is this a common Fault?
4) Would it make sense to change the other 3 Injectors at the same time?
Anticipated Thanks for any responses.
FFF (Frustrated Fiat Fool)
Just for the record, totally disappointed with this "54" Plate Eleganza and would never, ever buy another for friend or foe!
Other faults/issues/irritations with this Panda since brand new purchase:
1) After 1 year and 6 months, 16,000 miles, the radio/cd volume button fell off. Replacement cost around £5.00.
2) After 2 years, 21,000 miles, the power steering progressively "wears" the inside shoulders of both front tyres. Tyres require replacement even though plenty of depth/grip on the rest of the tyres. Balancing/Wheel Alignment checks have discounted any other possible reasons. Replacement cost for 2 Tyres £92.00.
3) After 2 years and 1 month, 24,000 miles, the complete light stalk/arm needed replacing because the headlights would switch off for no reason whilst travelling. Especially exciting when coming down country lanes at midnight.... Not! After heated discussions with the Franchise a 2 year service was "negotiated" for a cost of £260.00 which meant the light stalk/arm would be replaced under warranty at no extra cost, the car would also be serviced. Strange that the cost outside of warranty for stalk/arm part, vat and fitting pretty much came to the same figure but with no service... spooky! The 2 year service appears to be nothing more than a lot of "checks".
4) After 2 years and 6 months, 30,000 miles, the boot handle is showing intermittent opening efficiency i.e. sometimes it works, sometimes it doesn't. I have worked out the by pushing the handle away from you before pulling it towards you, does the trick. However, after reading other posts this also looks like a potential future expensive replacement repair.
5) After 3 Years, 35,000 miles, the exhaust started to vibrate and communicate to the underside of the car body via the means of morse code. Exhaust clamp had "rusted away". I puchased a replacement clamp and fitted it myself for a cost of £1.02.
6) After 3 Years and 9 months, 41,000 miles, the complete steering servo and ECU failed. After discovering this forum and lengthy painful communication with Fiat the initial cost of £920.58 was reduced/agreed to a cost of £164.50.
7) After 4 Years and 1 month, 44,000 miles, engine injector number four has failed. Cost unknown at this stage.
Conclusion:
Questions:
