dobloseven
Since we bought our 05 multijet the front wipers juddered.The large drivers side one seemed to have trouble turning over at the end of each stroke.The blade was almost new but I noticed that the arm was pressing it very hard against the glass,much harder than the passenger side or on our other vehicles (a nearly new doblo and an 02 reg renault master minibus,both with similar sized wipers).To reduce this pressure I removed the arm and unhooked the tension spring(not easy,best done with arm gripped in vice as there is a lot of force in it).After a bit of experimenting I found that hooking a 8mm spring washer between the spring and the link it hooks over makes it easier for the blade to turn over and eliminates the juddering almost completely.
