Panda4X4_Skydome
- Mar 5, 2006
- 76
- 23
Panda 4x4 1.2 - done 18000 miles - i've had it from new. It's started squeaking (when it does it it's a constant squeak and sometimes it's quite loud) from the rear right rear wheel. It doesn't do it all the time and never from cold. It also stops when breaking or when the car is going round a corner (either way - seems that anything that shifts the weight left or right stops it) and the squeak doesn't stop in neutral.
I thought it might be something stuck in the pad / dics but it's still going so I don't think it can be that. I tried to check but with just the right rear side wheel jacked up I can't even turn the wheel - is this the 4 wheel drive system and do I need both rear wheels off the ground or is the squeak maybe a stuck caliper that's stopping the wheel moving ?
I'm asking here before I take it to Fiat as a) the dealer isn't local and b) no doubt they will suggest new discs and pads all round
Thanks...
Thanks...
