ruinin
Established member
I am determined to do something about the rattling. It really spoils the great impression of the car. One of the guys here said that those cobblestones almost ruined his own car when he was in Prague. But Prague is not all cobblestones, the problem is that the tarmac roads here are full of very subtle or less subtle bumps and holes and that can really upset the silence of the cabin a lot.
Look what I found
http://www.botechs.com/m35/sm/ip.pdf
it is a whole book about diagnosis of rattle noise in infinity cars and it shows how helpful and professional the infinity guys are - they really try to do their best to help the customers and find and fix the rattle and i think it should be normal even with fiat - they should drive in the car with you,
check they know what rattle you have problem with, and try to fix it
The rattle kinds I have is really primitive and I can't believe it is not possible to fix it. But before I ask the unwilling staff at fiat garage, I will try to discuss and ask you for your tips or ideas
First: passenger airbag lid - it clearly rubs and squeezes against the external dashboard part on bumps - the infinity manual mentions some special foams or silicons that are made to fix this plastic against plastic noise
This is pain and i am very pessimistic about this one- it was reportedly fixed by Fiat already twice and it gets worse after each time they "fix" it. Plus they dismantle the whole dashboard and put some smelly stuff inside and the only result is smell and even more rattling.
Second: passenger head rest rattling - already fixed with a tape wrapped around the rod which made the rod sit firm inside the hole without play
Third: skydome plastic shades vibration - I am going to get some lead and glue it to the top of it so it makes it a bit heavier and prevent it from vibrating
Fourth: something knocking in both front doors when accelerating and braking - I can't fix this at all, must report to the mechanics, but it must be easy to fix and at least the sound is clear like anything
Fifth - something like a big plastic drawer somewhere under the trunk is
a bit shaking on little bumps - difficult to identify, but must be easy to fix once found
Sixth - all the ventilation knobs rattle on cobblestones but I can live with it
If you have found how to fix the most annoying ones or have experience from fiat that fixed it successfully, let us know. Let's help each other and encourage one another. Thanks
Look what I found
