Finally went to the Parts dept on Sat, so if you want to know how to put a light in the boot - this is how to do it:
Time: 5 mins
Difficulty level: easy peasy
1. Buy part: 60665239 L080 Ceiling Lamp (yes really). It comes complete with the bulb and costs £10.52 inc VAT.
2. Unscrew the screw holding the left side parcel shelf rest closest to the boot opening.
3. Unscrew the screw holding the left side parcel shelf rest (this should have a small oblong cutout - the same size as the lamp in it) closest to the back of the rear seat.
4. There are only two screws, so if you can see more, STOP at this point - as something is about to go horribly wrong...
5. Pull away the black trim/carpet - starting from pulling it out from under the rubber seal that runs around the boot opening - you will see that there is only about 15cm of it under the seal.
6. Carefully pull the trim from between the two locations where you have just removed the screws. It's quite tight, but you can slide the trim down and away.
7. You will now have revealed the wiring loom.
8. Note that there is a white connector lightly taped to the loom with masking tape and two wires coming out of it.
9. Remove tape and untangle connector and connecting wire.
10. Poke connector through a cross cut in the trim that is very close to the screw hole for the shelf rest that contains the oblong cutout for the light.
11. Connect the white connector to the boot light, and snap into the oblong cutout. At this point, the light should come on - because unless you are a contortionist, you have the boot open....
12. Push the black cable holder lug (that is connected to the boot light wire close to the connector) into the hole next to the bootlight. It stops the wire wiggling around....
13. Replace trim by sliding it back up between the car body and the shelf rests - and don't forget to slide it back under the boot seal.
14. Stand back and admire handywork and bathe in the glow from the, errr, pretty crap boot light and realise, it's still as light as a Cornish tin mine in there....
Good luck!
Time: 5 mins
Good luck!
