The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Panda (New)
Old 19-07-2008   #1
Trader Rating: (0)
100hp oil
iv now done 6500 miles and last nite it flashed up low oil presure cant believe used all it oil already had old cars that never used a drop
n find it inpossible to check the oil pull dip stick out n wipe it put it in then out to check n the hole dip stick has got oil on it lol, any ideas or anyone have same prob?
PANDA100HP
Tom100hp is offline
Old 19-07-2008   #2
HP.
HP.'s Avatar
Trader Rating: (0)
Re: 100hp oil
Has the end of the dipstick just got smears of oil on it or a definite line all the way around, part way up?
Blue Panda HP and Cinquecento 1242..... better than a bottle and a half of Prozac
HP. is offline
Old 19-07-2008   #3
The element of suprise!
100hpJames's Avatar
Trader Rating: (0)
100hpJames has donated! United Kingdom
Re: 100hp oil
make sure you check it when the engine is cold and car is on a level surface, shouldn't have a problem then, keep an eye on the oil in the future as they use quite a lot
Satin matt black wheels, red calipers, red badges, sports pedals, abarth tax disc holder, front and rear componants, de-oranged indicators and clear sidelights
Originally Posted by gaz_wrexham View Post
after mopping up the mess and sticking it back in the hole it worked
had a quick poke around but didnt manage to find anything
100hpJames is offline
Old 19-07-2008   #4
HP.
HP.'s Avatar
Trader Rating: (0)
Re: 100hp oil
Seems that some use a lot and some don't use any at all, a bit like Alfas.
HP. is offline
Old 19-07-2008   #5
Victor|100HP's Avatar
Trader Rating: (0)
Netherlands
Re: 100hp oil
Depends on the way you drive it. My 100HP uses a litre of oil (5w40) per 4700 miles.
Victor|100HP is offline
Old 19-07-2008   #6
HP.
HP.'s Avatar
Trader Rating: (0)
Re: 100hp oil
Looks like it depends how they were built. Mine uses virtually no oil at all and is caned quite a bit.
...or maybe 5w40 is too thin, if it's using that much.
HP. is offline
Old 19-07-2008   #7
paulbfd's Avatar
Trader Rating: (0)
paulbfd has donated! United Kingdom
Re: 100hp oil
Mine used a bit before it's first service, seems since it hasn't touched a drop.
Black 100HP
Alpine CDA-7944, PXA-H701 processor and RUX-C701 controller.
Hertz Mille MLK2 components, Mille 10" subwoofer and HP4 amplifier.
Chord Epic speaker cable and Anthem RCA leads.
paulbfd is offline
Old 19-07-2008   #8
Pandamonium.
DavePanda100's Avatar
Trader Rating: (0)
DavePanda100 has donated! United Kingdom
Re: 100hp oil
Mine is still at the same level the day I bought it 6 months ago.
New Orleans Blue Panda100hp
Audi R8 Style LED Lights : LED Sidelights : Italian Pressed Metal Style Number Plates : Italian Flag Wing and Boot Badges : Silver Indicator Bulbs : Panda Aerial Topper
DavePanda100 is offline
Old 20-07-2008   #9
Trader Rating: (0)
Re: 100hp oil
At 100 degrees a 5w-40 is going to be the same thickness as most day-to-day oils (0w-40, 5w-40, 10w-40) and it's at operating temperature that a car is likely to use it's oil. There's no way the engine in a Panda is high performance enough to need a thicker oil such as Mobil 1 15w-50 Motorsport Formula or Castrol Edge 10w-60. These would lead to a reduction in fuel economy too.
If the oil was too thin when it's cold (the first number in an oil's viscosity refers to it's flow rate at zero degrees) then the car would smoke on start up as the oil would have crept past the seals. I'm running mine on Mobil 1 0w-40 and haven't noticed this at all.
Mine does use a small amount of oil, but nothing untoward IMO considering the way it gets driven most of the time.
Ben
BenP is offline
Old 20-07-2008   #10
HP.
HP.'s Avatar
Trader Rating: (0)
Re: 100hp oil
True, but to use a litre in 5000 miles might not produce noticeable smoke.
HP. is offline
Old 20-07-2008   #11
ScoobyChris's Avatar
Trader Rating: (0)
Re: 100hp oil
I've put a litre in mine so far (half litre every 4k miles) but my car does tend to be driven harder than most. Topped up with some Castrol GTX semi-synth in mine, but I'm thinking of shifting to fully synth at the first service....
Chris
Holding up the traffic in a little Italian.........
ScoobyChris is online now
Old 21-07-2008   #12
Trader Rating: (0)
Re: 100hp oil
I brought my car new, its only used around 250ml of top up oil in the last 12,500miles. And you expect a small amount to be used as the oil gets around the engine bay etc when new
My advice is to be gentle with the car for the frist 1,000miles as a run in 'road' period.
I always let the car warm up without pushing it and give it 20-30secs to idle before switching off.
I would be really worried on a modern car if it used all its oil in 4700miles
Fiat_N_Fast is offline
Old 21-07-2008   #13
A Panda with Gadget's
Most Easterly Panda's's Avatar
Trader Rating: (0)
Most Easterly Panda's has donated! United Kingdom
Re: 100hp oil
I thought it was then the engine is cold it uses most oil as the metal has shrunk when cold allowing gaps between piston rings etc
Bright in White... ...Bright at night!
Look at those spots and the 240 watt of 4 Halogen bulbs!
Originally Posted by b1g1an View Post
You need to twist as you pull, just twisting then pulling isn't enough.
Originally Posted by Jai View Post
grip the meat, loosen the throat, relax and slide it in
If my post or someone else's has helped, say thank you using the Thanks Button \/
Most Easterly Panda's is offline
Old 21-07-2008   #14
Trader Rating: (0)
Re: 100hp oil
Both our Pandas seem to have reduced their thirst for oil since reaching the 30,000 mile mark. One is 1.2 the other 1.1 and they both consume more oil when driven for long periods at motorway speed.
doctorchris is online now
Old 22-07-2008   #15
Trader Rating: (0)
Netherlands
Re: 100hp oil
I drive it a bit harder than most people would.
Tags: ,
vB code is On
100hp oil (sludge) change after 6k. medlow Panda (New) 11 11-02-2008 19:27
100hp drinking all its oil every 4-5k grandemike Panda (New) 20 07-01-2008 14:25
100hp - Oil filter part number?? medlow Panda (New) 13 31-12-2007 00:15
100HP early oil change? mathew Panda (New) 12 16-06-2007 17:06
