| Advice...Fitting a cigarette lighter point.... Hi, I have an 06 plate Fiat Panda Active and when i bought the car i found there was no cigarette lighter point. Obviously i would like to get one fitted, as theres only so much battery life on a sat nav...and i need it for long journeys! So i was wondering if anyone has had this done and knows of a rough price of how much it would cost and any recommended places to go get it done, any well known garages that have good reputations? I'm new to driving so don't know much yet! Any help would be appreciated, Thanks! ![]()
| Re: Advice...Fitting a cigarette lighter point.... I could do with one too, for my sat nav. I imagine it would be a bit pricey....... I've seen a solar powered charger for phones and sat navs in Maplin, so may get one of those.....?
| | #3 | ||
| Re: Advice...Fitting a cigarette lighter point.... www.dun-bri.com/ShowDetails.asp?id=129 This link will give you an idea of the cost of a socket. Then you need to find a suitable panel to drill and fit it. Finally, you need to wire it to a suitable fuse on the fusebox. Sadly, the centre console cannot be used as there is a tray on the 1.1 Active rather than a raised section where the socket fits on other models. I've thought about this modification for my daughter's car and concluded that inside the glove box might be a good place. Otherwise, you can get a bracket to hold the socket and could mount it below the dashboard.
| | #4 | ||
| A Panda with Gadget's | Re: Advice...Fitting a cigarette lighter point.... I just can't get over the fact that Fiat don't fit a standard thing like a power point in the base model Panda. It really does seem silly. Have you gone to a dealer to get a price of all the parts as they might include the missing center console thingy. Jon.
__________________ Bright in White... Look at those spots and the 240 watt of 4 Halogen bulbs!If my post or someone else's has helped, say thank you using the Thanks Button \/ | ||
| | #5 | ||
| Re: Advice...Fitting a cigarette lighter point.... if your only going to run a sat nav off it get a cheap 12v extension socket ![]() wire it directly to the battery or solder it to the fuse box live supply via a fuse say 3A that should work fine tuck it into the glove box when not in use .. or pannel mount something like this... ![]() both from maplin.com
__________________ What Goes Up Must Come Down..... | |||
| | #6 | ||
| Re: Advice...Fitting a cigarette lighter point.... Aldi have a converter in at present for £2.99 that plugs into an existing socket and provides 3 sockets. It is supplied with sticky pads and screws to fix it to the car interior. There's no reason why you could not cut the plug off one of these and wire it into the fusebox. The wire is quite short but curly so would probably stretch a reasonable distance under the dashboard. Probably the cheapest option, provides you with 3 sockets and even has an on/off switch so you could wire it into a permanent supply such as the radio supply. If worried about overloading it, an in-line fuse could be wired in.
| | #7 | ||
| A Panda with Gadget's | Re: Advice...Fitting a cigarette lighter point.... I brought one of the above from Lidl the other day which had a 2.6/2.8m cable which might be better. Jon.
| | #8 | ||
| Re: Advice...Fitting a cigarette lighter point.... Why not find a higher spec Panda at a scrap yard and take the bits off that?
__________________ 2000 Silver barchetta. Windstop, bootrack, air-con, HID lights, DTR exhaust, GoodYear Eagle F1s, front spoiler, cd-changer, 6 infinity speakers, 3rd brake light | |||
| | #9 | ||||||
| Panda Powered Squirrel |
Is it me or have the scrimped on the ignition lock too ? Most cars I have driven have had an 'ACC' position where some electrics are powered up but not everything (ideal for sitting in the car with the radio on). The Panda has Off, Mar and spin the starter, so in MAR while you listen to the radio all manner of electrical & electronic beastie is munching on your battery. Trev
| | #10 | ||
| Re: Advice...Fitting a cigarette lighter point.... On my Mjet I can turn the radio on with the ignition off? Don't they all do that? JON
| | #11 | |||
| Panda Powered Squirrel | I,ll have a try tomorrow, if my new radio will play ball !!!
| | #12 | |||
One thing I do like with Fiats is the headlights going off with the keys. Do new Panda's do this? And you have to push a button by the key and click it back another point to turn the parking lights on? Jon.
__________________ Bright in White... Look at those spots and the 240 watt of 4 Halogen bulbs!If my post or someone else's has helped, say thank you using the Thanks Button \/ | |||
| | #13 | |||
It'd only really be an issue if you were sitting for several hours at a time like this.
__________________ Blue Panda HP and Cinquecento 1242..... better than a bottle and a half of Prozac | ||||
| | #14 | |||
![]() Jon.
| | #15 | ||
| Re: Advice...Fitting a cigarette lighter point.... If you have electronic ignition, no worries. If you have points, true - it's possible you could maintain a current through the coil. I have heard the claim about burning the coil out when kept on, but don't know anyone it's happened to and think it might be a myth going back to the dark ages of motoring.
| The following user says "Thank You!" to HP. for this useful post: | ||
Most Easterly Panda's (21-07-2008) | ||
| Cigarette Lighter | hobx | Ducato | 3 | 13-06-2008 19:34 |
| Cigarette Lighter | Tris Harris | Punto | 5 | 04-10-2007 20:14 |
| Fitting a cigarette lighter | BenW | Panda (Classic) | 21 | 01-10-2006 08:55 |
| Cigarette lighter... | SlinK | Punto > Technical | 7 | 30-11-2004 11:35 |
| Where is the cigarette lighter? | Pashel | Uno | 2 | 14-04-2004 19:14 |
