The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Panda (New)
Old 16-07-2008   #1
clair80's Avatar
Trader Rating: (0)
Tyre pressure
Hi, could someone please tell me what pressure the tyres should be. my manual tells me in Bars. but i need to know properly e.g 30. thank you
clair80 is offline
Old 16-07-2008   #2
A Panda with Gadget's
Most Easterly Panda's's Avatar
Trader Rating: (0)
Most Easterly Panda's has donated! United Kingdom
Re: Tyre pressure
I don't personally know, but know on the garage compressors there is a button to change from P.S.I. to BAR if it helps
I think you can also press how many bar it is, then the button to change it to P.S.I. and it will tell you how many P.S.I. it is
Bright in White... ...Bright at night!
Look at those spots and the 240 watt of 4 Halogen bulbs!
Originally Posted by b1g1an View Post
You need to twist as you pull, just twisting then pulling isn't enough.
Originally Posted by Jai View Post
grip the meat, loosen the throat, relax and slide it in
If my post or someone else's has helped, say thank you using the Thanks Button \/
Most Easterly Panda's is offline
Old 16-07-2008   #3
clair80's Avatar
Trader Rating: (0)
Re: Tyre pressure
Thx but when i go to check my tyres myself at morrisons ya have to put numbers in e.g 30 .
clair80 is offline
Old 16-07-2008   #4
Panda Powered Squirrel
udtrev's Avatar
Trader Rating: (0)
udtrev has donated! United Kingdom
Re: Tyre pressure
I'll try and dive out in the morning and raid the handbook.
Trev
Originally Posted by Most Easterly Panda's View Post
did you know that the Fiat dealership manuals recomend that the engines are dropped out the bottom of the engine
I was having a senior moment Silly me
Clarkson may have failed to kill a Toyota Hilux - I, unfortunately, succeeded :-(
udtrev is offline
Old 16-07-2008   #5
Trader Rating: (0)
Re: Tyre pressure
Yes I know, but if you look at all the buttons (there's normally about 4/5) one say's P.S.I./BAR which changes the units
Old 16-07-2008   #6
Herts Hillhopper's Avatar
Trader Rating: (0)
Re: Tyre pressure
Hi Clair
1 bar = 15psi (purists will tell you its 14.8...)
So, the pressures for 'normal loading' for all Panda except 100HP and 4x4 are
Front 2.0 bar = 30 psi
Rear 1.8 bar = 27 psi
For full load, both front and rear go to 2.2 bar, which is 33psi
[added later]
For the Multijet, as above, but full load is 2.3 front, which is 34.5!
The 4x4 is 2.2 front, 2.0 rear which gives 33F / 30R, and full load 2.3 all round which is 34.5 at each corner
[and later still!]
Forgot the spare: Spacesaver spare is 2.8bar, or 42(!) psi
Pete
Herts Hillhopper is offline
The following user says "Thank You!" to Herts Hillhopper for this useful post:
Most Easterly Panda's (16-07-2008)
Old 17-07-2008   #7
udtrev's Avatar
Trader Rating: (0)
Talking Re: Tyre pressure
My handbook has hand written values of 29 & 26, but not going to quibble over 1 psi
In my case I will be putting my spare at 30 too (it's full size not a spacesaver - if you want that damn thing yell !!)
Trev
udtrev is offline
Old 17-07-2008   #8
ScoobyChris's Avatar
Trader Rating: (0)
Re: Tyre pressure
As another "spanner in the works", my experience of garage tyre pressure gauges is that while they show the same numbers on the screen they all appear to have been calibrated to a different standard (up to 5psi different!) which has led to me distrusting them.
I've now bought myself a mechanical foot pump which fills me with a bit more confidence as it at least now seems to agree with my tyre pressure gauge (made by a different manufacturer). Pumping up the space saver that first time was a bit of effort though
Chris
Holding up the traffic in a little Italian.........
ScoobyChris is offline
Old 17-07-2008   #9
udtrev's Avatar
Trader Rating: (0)
I cheated - I have one of them 12v power station thingies, it includes a pump
udtrev is offline
Old 17-07-2008   #10
Trader Rating: (0)
Re: Tyre pressure
The other problem with using garage forecourt pressure gauges and pumps is that the tyre pressures should be measured cold. Therefore if you have driven more than about a mile to the garage the tyres are warm and will end up underinflated.
Investing in a 12v electric pump and a reliable pressure gauge is well worth it.
doctorchris is offline
Old 17-07-2008   #11
Trader Rating: (0)
Re: Tyre pressure
The advantage of doing long shifts at a petrol station, do tyre check when my shift has finished with nice cold tyres
I also use a digital pressure reader because I to don't trust the compressors read out as far as I can throw one
Jon.
Old 17-07-2008   #12
Shropshire UK
Ffoxy's Avatar
Trader Rating: (0)
Ffoxy has donated! United Kingdom
Re: Tyre pressure
Jon.
Digital tyre pressure gauge from Halfrauds £5...
Ex Suzuki SV1000S jockey, now just me and my 1.9 MJet Grande Punto Sporting in New Orleans Blue. 193.8 Bhp and 261ft lbs torque.
Ffoxy is online now
Old 17-07-2008   #13
Trader Rating: (0)
Re: Tyre pressure
Think mine was £4 from wolly's.
vB code is On
tyre pressure scorchedbee Grande Punto > Technical 7 24-06-2008 11:07
tyre pressure dinom Panda (New) 2 18-02-2008 21:15
Tyre pressure? StiloBoy Stilo > Technical 33 17-04-2007 18:20
Tyre Pressure Ste Unit Bravo/a > Styling 3 05-03-2006 23:20
Tyre pressure for spare tyre Cinquelover Cinquecento / Seicento 2 19-02-2006 22:02
