| I have my own title! :) | Clutch / Geabox Issue - 100HP Hi, Got my car booked in at Mangoletsi (Wilmslow) on Thursday morning. Basically over the passed week my clutch pedal hasn't felt right at all. It sometimes doesn't feel like its coming back up quickly and being a bit spongy. I've had quite a few issues where you car refuses to go into gear without several further presses of the clutch pedal. Its even stalled on a couple of occasions as well... ![]() Anyone else had similar clutch pedal / gearbox related problems ![]() Car is an 08 plate and has only done 5000 miles. Andy
__________________ ![]() Black Fiat Panda 100HP 2008 | Red Calipers | Diadem Bulbs | ||
| Re: Clutch / Geabox Issue - 100HP Sounds like a hydraulic problem, hopefully easy to fix.
__________________ Blue Panda HP and Cinquecento 1242..... better than a bottle and a half of Prozac | |||
| | #3 | ||
| Mr Pedantic | Re: Clutch / Geabox Issue - 100HP If you told me those symptoms and it was a Coupe, it'd be the clutch slave cylinder leaking, which is fairly common. It could be the same on the Panda, though I can't recall any problems with them. Have you checked the hydraulic fluid level? If you have a leak it'll be low... | ||
| | #4 | |||
Fortunately its not mega complicated to fix it. New slave or master cylinder and a bit of bleeding. Easily do-able i should think in a days work.
__________________ 2008 Red Panda 100hp 1996 JDM Integra Type-R | ||||
| | #5 | ||
| Mr Pedantic | Re: Clutch / Geabox Issue - 100HP Warranty ![]() It takes about 30 mins to change on a Coupe, and that includes removing the battery tray and bleeding the clutch. If it is the slave cylinder, it should be simple. | ||
| | #6 | ||
| I have my own title! :) | Re: Clutch / Geabox Issue - 100HP Thanks for the comments guys, it does seem fairly intermitent. So hopefully its something fairly trivial to sort out. I'll let you know what the outcome is.
| | #7 | ||
| I have my own title! :) | Re: Clutch / Geabox Issue - 100HP Mangoletsi Dealer Report "Right sir, it needs a new clutch master cylinder, but theres none in stock. We will call you when one comes in" Anyone else needed a new master or slave cylinder so soon (5000 miles) ![]() Regards Andy
| | #8 | ||
| Re: Clutch / Geabox Issue - 100HP I have a Panda 100hp but i thing that they don't have a hydraulic clutch system. Is this true?
| | #9 | ||
| I have my own title! :) | Re: Clutch / Geabox Issue - 100HP Right fully repaired now by Mangoletsi. New master clutch cylinder old one was leaking fluid. And they also put 1/2 a litre of engine oil in. Cars running perfect now very happy with their service. Andy
| | #10 | ||
| Tags: 100hp, clutch, gearbox, stalling |
| EVO issue 120, something for you 100HP fans | AndyWoodall | Panda (New) | 33 | 09-07-2008 22:25 |
| Clutch/clutch cable problem issue (again) ??? | MikeyD | Cinquecento / Seicento | 27 | 29-02-2008 15:01 |
| Clutch Adjust Issue | soopahfly | Cinq/Sei > Technical | 1 | 17-06-2007 13:40 |
| Gearbox/clutch issue | Stickman | Cinq/Sei > Technical | 9 | 16-04-2007 20:20 |
| Geabox problems | Wah | Cinq/Sei > Technical | 5 | 21-12-2004 23:53 |
