The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Panda (New)
Old 14-07-2008   #1
BCD
Trader Rating: (0)
How much power does the radio use?
Today, I was sat in a car park waiting for someone when my mind started to wander.
I had the radio on, but the ignition was off. How long would it take to flatten the battery doing this? I guess it's ok in short bursts, but if I were to do it for, say, two hours.......?
BCD is offline
Old 14-07-2008   #2
trackdayqueen's Avatar
Trader Rating: (0)
Re: How much power does the radio use?
The radio doesn't use much power. Would most likely be okay if it was on all day really.
Would easily be okay for two hours.
2008 Red Panda 100hp on order!
1996 JDM Integra Type-R
trackdayqueen is offline
Old 14-07-2008   #3
Pandamonium.
DavePanda100's Avatar
Trader Rating: (0)
DavePanda100 has donated! United Kingdom
No need to worry about it flattening your battery if left on, it turns it self off after about 15 minutes, well mine does in the 100hp.
New Orleans Blue Panda100hp
Audi R8 Style LED Lights : LED Sidelights : Italian Pressed Metal Style Number Plates : Italian Flag Wing and Boot Badges : Silver Indicator Bulbs : Panda Aerial Topper
DavePanda100 is offline
Old 14-07-2008   #4
Trader Rating: (0)
My BMW 3 Series cuts power after 30mins - as did my old Citroen C8. Was frustrating at times as you'd have to re-start to re-set the timer. However, prefer this to a flat battery any day!!
thelurve is offline
Old 14-07-2008   #5
Trader Rating: (0)
Not sure about on the Fiats, but i know Fords use a system called 'one hour' on theirs... so it obviously switches itself off after an hour!
When 17 - Panda 100HP
rd27 is offline
Old 14-07-2008   #6
Trader Rating: (0)
There is a timer you can set for 20minutes. Think there is an option to turn the timer off so the radio stays on. IIRC.
It's in the options I believe.
Old 14-07-2008   #7
Forum Moderator
T14086's Avatar
Trader Rating: (0)
T14086 has donated! United Kingdom
depends how load you have it
EDIT...load? I ment loud.
T14086 is offline
Old 14-07-2008   #8
A Panda with Gadget's
Most Easterly Panda's's Avatar
Trader Rating: (0)
Most Easterly Panda's has donated! United Kingdom
I've sat in loads of different cars for hours at a time with the CD / Tape player blasting out, no effect/problem with starting after
Should be fine for a long time.
Bright in White... ...Bright at night!
Look at those spots and the 240 watt of 4 Halogen bulbs!
Originally Posted by b1g1an View Post
You need to twist as you pull, just twisting then pulling isn't enough.
Originally Posted by Jai View Post
grip the meat, loosen the throat, relax and slide it in
If my post or someone else's has helped, say thank you using the Thanks Button \/
Most Easterly Panda's is offline
Old 15-07-2008   #9
ScoobyChris's Avatar
Trader Rating: (0)
Annoyingly I've found the maximum the Panda radio will stay on for is 20 minutes at a time, whereas all my previous cars had a 1 hour timer. Clearly the Blaupunkt designers have never had to sit in a car park waiting for their other half to "just nip into the shop"
Chris
Holding up the traffic in a little Italian.........
ScoobyChris is offline
Old 15-07-2008   #10
Trader Rating: (0)
lol.
Old 15-07-2008   #11
Herts Hillhopper's Avatar
Trader Rating: (0)
Not quite: you're right in saying in the radio's menu you can select 'ignition timer'. The options are 'off' or '20 minutes'.
If you choose 'off', the radio will go off as soon as you turn the key to off. If you set '20 mins', the radio will stay on for 20 mins after you take the out, unless you turn the radio off manually. Whatever it's set to, if you turn the radio on without the key turned in the ignition, the radio automatically goes off 20mins later.
Pete
Herts Hillhopper is offline
Old 16-07-2008   #12
hp_source's Avatar
Trader Rating: (0)
when i got my car it was set to '20mins' but i found it very annoying to have to turn it off manually everytime I got home/to work. So I changed it to 'off', which now means if I need the radio on afterward (the shopping scenario above ) then I just press the on button and get 20mins listening.
Panda 100hp - New Orleans Blue - Standard (At the moment )
hp_source is offline
vB code is On
Power Steering/Power Assisted Steering Buffy Cinq/Sei > Technical 5 30-03-2007 13:01
Help, with my radio GP184 Grande Punto 6 14-10-2006 20:37
My new radio santa Stilo 9 27-06-2006 11:46
No power to my radio ?? Dame2003 I.C.E 1 20-09-2003 22:20
