Lamps by Post - For all your lighting needs
Thread Tools
Old 3 Weeks Ago   #1
Underbody
Hi guys.
I know the rear axle/ springs need a yearly treatment of oil/wax/paint, anywhere else advisable while I'm under there!
leroya500 is offline Reply With Quote Quote
Old 3 Weeks Ago   #2
Re: Underbody
Rear drums are a good shout if fitted. They look very scabby after a short while.
Also the tops of the rear struts came get a pile of crud up there if it's been anywhere near mud, clean out and a shot of oil is a good idea.
Likes leroya500 liked this post
Alexiloki is offline Reply With Quote Quote
Old 3 Weeks Ago   #3
Re: Underbody
So here's what I've done
Painted the bottom of the spring cups with underseal
Sprayed the backing plates of the rear brakes and drums with one thin coat of stone chip, also sprayed the springs with one coat of stone chip
Made a home mix of gear oil and thinners to spray inside the spring cups.
All the above done after an attempt to get the road dirt off said items, but it was pretty ingrained on them.
Repeat next year?
Old 3 Weeks Ago   #4
2014 Panda Lounge 1.2
murphyv310's Avatar
murphyv310 has donated!
murphyv310 is an honorary friend of the forum :)
Re: Underbody
Hi.
The only thing I'd not use is underseal, it can get water trapped behind it and actually make things worse.
Make sure there is no rust initially and if so clean it off with a wire brush, then use Bilt Hamber De-oxit rust converter, either use their wax spray or Waxoyl. Keep the beam clean, even a wash with a garden hose is enough, make sure the holes in the cups are not blocked with grit or even wax as these need to drain.
After that a check each year and re-application of the wax if necessary will be fine.
Likes g4jvf, leroya500 liked this post
Cheers Trevor
murphyv310 is offline Reply With Quote Quote
Old 3 Weeks Ago   #5
Re: Underbody
There was no rust just road debris
Likes murphyv310 liked this post
Thread Tools
(T) Underbody Protection SB1500 Panda 13 10-10-2016 16:04
(G) underbody opinions? benny279 Punto (Mk2/2b) 66 25-06-2013 20:54
(T) Underbody rust - how to sort ianlewis Punto (Mk1) 4 22-01-2012 00:20
(T) underbody repair blackpool Panda (Classic) 4 01-11-2011 10:47
(T) Underbody Weathershields Ralph2 Stilo 18 03-02-2008 13:41
