Thread Tools
Old 30-06-2017   #1
Goudrons has donated!
Clonks and rattles
I can no longer put it off, I'm going to have to roll around the floor this weekend trying to find the source of our Pop's clonks and rattles on the front.
For a while it's had a muted rattle over rougher roads, that's pretty much all of them around here, particularly over the crappy surface of the work car park.
I swapped out the arb droplinks a few months ago and it did help a little, but not much.
I've now a slight steering wander and higher speeds, there's definitely more of a metallic, looser rattle to it (front left) and I can now feel a bit of a click/knock on the steering if I rock it back and forth (again it seems to feel like it's the front left).
I think all the friggin' road humps have caused it and I'm guessing it's more than just a simple swap out of one part, Grrr!
Goudrons is offline Reply With Quote Quote
Old 30-06-2017   #2
Moderator
Re: Clonks and rattles
Quote Originally Posted by Goudrons View Post
Track rod ends & bottom swivels would be the first two places to look. If it's that noticeable when driving then the cause should be obvious on proper inspection; easiest if you can get a second person to gently rock the steering wheel from side to side until it just starts to turn the wheels (EPAS off for this). Ideally check it on turn plates with the weight on the wheels (like they do at MOT time).
I'll swear some of these road humps are sponsored by Kwik-fit. Sadly not a problem that's confined to Fiat, but posts on this forum suggest their OEM suspension parts are less durable than many. Buying quality aftermarket alternatives at replacement time would seem sensible if you plan on keeping the car.
Interestingly my 1.2 Panda 169 is still on all of its original parts after almost 80k; running on 13" wheels & skinny tyres does seem to prolong the life of the steering & suspension components.
Well you'll probably want to change whatever it turns out to be (pardon the pun) as a pair. Remember to check the tracking once it's all sorted.
"Just 'cos you're not paranoid, doesn't mean they're not out to get you"
jrkitching is online now Reply With Quote Quote
Old 30-06-2017   #3
When I changed the arb droplinks, the track rod ends and rack tie rods seemed fine, yet it did still rattle.
Now that the wander/metallic click has started, I'm leaning towards larger wishbone bush that's fecked.
The knock when rocking the steering doesn't feel loose in the hand at the steering wheel, it feels a bit weightier, like it's further down somewhere after the road wheels have moved.
We'll see tomorrow, though I must remember to charge the battery up on my lazy spanner!
Old 30-06-2017   #4
Quote Originally Posted by jrkitching View Post
It's why the Mrs wanted shot of her Lounge and into the Vitara we've just bought.
It's a joke, we live in the city centre yet feel we need the ride height of a off road/crossover due to the humps.
I'm green in the eye with Squadrone Rosso and his plan for a 595, I've been out myself looking at them, ST's etc, but if I got one, I might as well drive it off a cliff and bounce to work on my bare arse!
I'm going to count all the humps on my way home from work today and clock the mileage, it's about three miles home (so just under an hours drive!) and I reckon there's more than 60 humps!
Likes petercresswell liked this post
Old 01-07-2017   #5
2014 Panda Lounge 1.2
murphyv310's Avatar
murphyv310 has donated!
murphyv310 is an honorary friend of the forum :)
Blimey....... it would be quicker walking home, hopefully your knees and hips would be OK as you'd be on the pavement and not walking on the humps
Likes JCarp16 liked this post
Cheers Trevor
murphyv310 is offline Reply With Quote Quote
Old 02-07-2017   #6
47 humps in 3.1 miles.
Walk, on the pavement, around Central London!
Are you mad?
I've had her up and had a good route around looking for the clonks and I can't see anything obvious with the suspension.
Track rods and track rod ends ok.
Rack bolted down tight.
Wishbone bushes appear tight enough.
Lower ball joints good.
ARB droplinks good and the ARB it's self appears tight in the D bushes.
Struts and top bushes appear solid too.
What I did detect was a bit of play in the steering that knocked a bit when the steering is slung one way then the other quickly.
I chased it down the column and that seems tight, so presume as the track rods etc are tight, the rack is loose and rattling in it's casing over rough roads.
The play is tiny, a few mil each way and it only seems to rattle over surfaces like cobbles, so I reckon the pinion bush/bearing might be sloppy.
Old 02-07-2017   #7
murphyv310's Avatar
Did you use a breaker bar and lever everything? Rattles are a pain in the butt to find and very frustrating. The old Rover rattled badly and had top mounts lower wishbones bushes etcetera and still rattled, always passed its MOT with no advisory but it drove me mad.
I hope you find the problem and tell us the secret.
Cheers Trevor
Old 03-07-2017   #8
It'll have to do for a while, now I know nothing is going to fall off!
Thanks Alexiloki thanked for this post
Likes Alexiloki liked this post
Old 03-07-2017   #9
Valid point, you don't want anything dropping off I once lost a backbox on the M42. Wasn't exactly fun explaining that to the Highways Agency as they needed to recover it
Alexiloki is offline Reply With Quote Quote
Old 03-07-2017   #10
Moderator
Quote Originally Posted by Alexiloki View Post
Many years ago (when sales of far eastern cars had just started to take off), I was at a conference and remember a Birmingham-based parts manufacturer moaning very publicly about how the increasing number of Japanese components on British roads was threatening their business.
Someone quickly came back with a comment about the number of UK components on British roads, pointing out that he'd swerved around two on the M6 getting there. It brought the house down.
Old 03-07-2017   #11
That's just beautiful! Incidentally my disaster on the M42 was due to a British Leyland disaster vehicle I brought as a cheap runaround. Oh the irony
Old 03-07-2017   #12
Marina/Allegro/mini?
leroya500 is offline Reply With Quote Quote
Old 03-07-2017   #13
Quote Originally Posted by leroya500 View Post
Allegro 1100 British Leyland brown with a delightful vinyl interior that used to try and burn my a**e off when I got in. Brought it after my first car was knicked from a auction to get my by. 75 notes, 11 months mot and a sniff of tax. This was back in 2005 .
Being a younger lad I wasn't around for the British Leyland saga, but my old man worked for them for nearly 45 years ending during the BMW reign and my grandad worked for them until the late 80's during the Austin Rover Group. They ribbed me mercilessly for months after buying it, but it was pretty reliable, would run on pretty much any volatile liquid and could be fixed with a lump hammer and a plate of smash if needed. Sold it just over a year later for 1200 to a BL lover. To each their own!
Old 04-07-2017   #14
Trader Rating: 1
petercresswell has donated!
petercresswell is an honorary friend of the forum :)
I had an Allegro 1300, one of the last ever built and it was not as bad as made out. It did drink rather a lot of oil though. In fact every 3000 miles i would drain a gallon from my Citroen and keep it for use in 'Grot' who would willingly use all of this and more in the few weeks till the next change came round. Oddly it neither smoked much, nor leaked on the garage floor. I got 10 for mine as scrap after carefully dismantling it after rust finally ate the axle mounting points. Next day I git 20 for an old fire grate...... Just about says it all.
petercresswell is offline Reply With Quote Quote
Old 04-07-2017   #15
I too had a 1300 Allegro, in yellow. It actually was a quite reliable car - apart from trying to kill me once*, I had no issues with it.
*Pootling along on the A59, put my foot down to overtake something, pulled back in and she kept accelerating! All I could do was put it into neutral, then turn ignition off once I stopped. A look under the bonnet revealed the heatshield which guarded the carburettor from exhaust manifold had broken off and then wedged in the throttle linkage. Threw away heatshield, and never had any more problems!
Fillipe is offline Reply With Quote Quote
Thread Tools
Panda 2012+ Rattles jimweir485 Newbie Central 5 21-01-2013 00:50
(T) gearbox fitted, now clonks when pulling away. leebex Punto (Mk2/2b) 17 31-12-2011 23:07
(T) Big clonks from undercar fender mender Stilo 5 01-08-2011 08:52
(T) clonks and rattles dantmjones Barchetta 5 26-07-2006 02:15
(T) Front clonks. Morty Mort Uno 7 07-06-2005 08:05
