FIAT Auto Specialist Team
Thread Tools
Old 16-06-2017   #1
2012 Panda Pop rear disk conversion?
Hey there mysterious strangers of the Interwebnet,
I'm pondering the idea of converting my Panda (Ling Ling) to brake disks all round? I know drums can be more efficient on a day to day basis and blah, blah, blah! I'm not looking for reasons against doing it, just possible ways of doing it?
I thought if the 500 or something had rear disks I could just replace parts? i'm looking for a bolt on solution basically?
Any thoughts?
thanks!
MunchBunch is offline Reply With Quote Quote
Old 16-06-2017   #2
Re: 2012 Panda Pop rear disk conversion?
4x4 models have rear disc brakes... but also have different rear suspension arms too, which may mean the parts don't interchange. The 2012-onward 4x4 Panda uses different rear brakes to the 500 (unlike the 2004-2012 model, which was largely a 500 in disguise and where the brakes were identical) the post-2012 model has fewer parts in common with the 500 (and is I believe more closely related to a Brazilian-made Fiat)
2013 Panda 4x4 :: North Herts :: Remember, if you find a post helpful, press the smiley face 'thanks' button below
Herts Hillhopper is offline Reply With Quote Quote
Old 16-06-2017   #3
Small Fiat Fanatic
Squadrone Rosso's Avatar
Squadrone Rosso has donated!
TBH, even the basic cars aren't in anyway under braked.
Simon
Green Fiat Panda Cross TA ~ Red Seicento Abarth ~ Red Alfa Romeo Spider Series 4 ~ Silver/Black Toyota C-HR Hybrid
Squadrone Rosso is offline Reply With Quote Quote
Old 17-06-2017   #4
Quote Originally Posted by MunchBunch View Post
... I know drums can be more efficient on a day to day basis and blah, blah, blah!...
Any thoughts?
thanks!
Can't agree - since their handbrake issues were sorted out about thirty years ago, discs have been better in every respect.
babbo_umbro is offline Reply With Quote Quote
Old 17-06-2017   #5
2014 Panda Lounge 1.2
murphyv310's Avatar
murphyv310 has donated!
murphyv310 is an honorary friend of the forum :)
Hi.
Even if there was a way to fit discs to the rears, it would be termed a modification and insurance would need to be informed.
If you ever owned a Rover 75 you'd be over the moon with the simple and basic drums in the Panda. The Rover had silly little separate hand brake shoes, a soft metal compensator that stretches so after only a few hard uses of the lever it was nearly vertical. The brakes I have to say on my Panda tick all the boxes.
Cheers Trevor
murphyv310 is offline Reply With Quote Quote
Old 17-06-2017   #6
Turkey
Quote Originally Posted by Herts Hillhopper View Post
Technically, the 500 is a Panda in disguise, as it took 3 years of development after they started selling the '04 Panda to turn one into a 500 rather than come up with the 2 door Panda 100hp everbody wanted. Basically every current European Fiat model bar the new Aegea/Brava can have their lineage traced back to the good old 04 Panda.
As for the matter at hand, I'm going to err on the side of "it's doable" in that I doubt Fiat bothered to re-engineer the whole rear subframe and hard points between the regular Panda and 4x4, so it's entirely plausible to find a crashed 4x4 from a breaker yard, take out the whole rear suspension, hubs, brakes and wheels, and bolt it onto the regular Panda since they're both trailing arm torsion beams. This is, however, based entirely on the speculation that Fiat is as lazy as I think they are and all the bolts, hard points and undercarriage will line up just fine. Being Fiat, they're also just as likely to have gone about scratching their left ear with their right elbow, gone the cheapest route, and have the engineering interns re-design everything to make it work as cheap as possible, resulting in a complete lack of interchangeable parts and a nightmare to work on.
oyumurtaci is offline Reply With Quote Quote
Old 17-06-2017   #7
Quote Originally Posted by oyumurtaci View Post
I would assume that latter option is more likely!
Likes oyumurtaci liked this post
Old 17-06-2017   #8
Maybe these will help? Close up drawing of the rear suspension from the disc-braked 4x4 model: https://www.fiatdalys.lt/diagrams/34...84BE1BB720.png
and for the 2 wheel drive with rear drums...https://www.fiatdalys.lt/diagrams/0E...A02B335AFA.png
If the hub carrier marked '5' in the 2 wheel drive rear end can somehow fit the various locating holes for the 4x4 version (where of course the hub also has a driveshaft connected to it) then maybe you can?
On the 4x4, the rear callipers fit to this part https://www.fiatdalys.lt/diagrams/B4...527D2319CA.png - using the two rearmost holes in the item labelled '1' (the arrow of '1' points to one of those holes)
Old 19-06-2017   #9
muttleysdad has donated!
Does the brake distribution thingy under the bonnet need changing or adjusting for disks on the back? I tried this years ago on a Ford Escort. The car was un-drivable as the rear brakes snatched too hard and would lock up under normal braking. The system was set up for drums on the back and applied too much pressure to the rear.
Just a thought.
Likes Cheguava, oyumurtaci liked this post
muttleysdad is offline Reply With Quote Quote
Thread Tools
FS all you need for a rear disk conversion James FIAT Boo Archives 8 12-02-2007 19:02
rear disk conversion colin FIAT Boo Archives 2 14-03-2006 19:42
rear disk conversion ned FIAT Boo Archives 4 13-10-2005 23:28
rear disk conversion colin FIAT Boo Archives 7 28-03-2005 03:01
