Thread Tools
Old 10-06-2017   #1
2014 Panda Lounge 1.2
murphyv310's Avatar
murphyv310 has donated!
murphyv310 is an honorary friend of the forum :)
Unhappy HELP. Lambda sensor fuse number and location.
Hi.
After an return of the hesitation I have checked the live data and it's looking like there is no supply to both banks for the heaters of the lambda sensors.
I can find no reference to a fuse for them in the handbook, I cant believe Fiat have no fuse for these in the Panda so I can only assume its not mentioned in the handbook.
Can someone tell me the fuse number and location please. The car is a 2014 Panda 1.2 both lambda sensor cables run under the ECU and no doubt into the under bonnet fuse box.
Help please as this getting frustrating now
Cheers Trevor
murphyv310 is offline Reply With Quote Quote
Old 10-06-2017   #2
murphyv310's Avatar
Re: HELP. Lambda sensor fuse number and location.
A wee bump on this..... anyone?
Cheers Trevor
Old 10-06-2017   #3
Look for condition of heaters from a cold start, that's when they should definitely be on.
jackwhoo is offline Reply With Quote Quote
Old 10-06-2017   #4
Check wiring diagram for fuses.
I don't think they are fused from ECU to heaters.
Put me right if I'm wrong.
Old 10-06-2017   #5
murphyv310's Avatar
Quote Originally Posted by jackwhoo View Post
Thanks Jack.
Not to be fused is a serious issue, the heaters can short out and without fuse protection could be termed a fire risk. I wasn't able to do further checks today but I'll check for 12v at the heater when I can.
Cheers Trevor
Old 10-06-2017   #6
Quote Originally Posted by murphyv310 View Post
Thanks Jack.
Possibly the ECU is programmed to protect the heater circuits?
Old 10-06-2017   #7
The mil should light and a code set if either lambda heater non functional.
There is a separate code for each heater.
Old 10-06-2017   #8
murphyv310's Avatar
I agree, Alfa Obd and Torq actually report the same issue, oddly the MIL light is off.
Cheers Trevor
Old 11-06-2017   #9
What are the pxxxx codes you have?
Old 11-06-2017   #10
murphyv310's Avatar
Hi Jack.
I'll need to check it again later as my memory is rubbish and I also forgot to write it down..... 63 and a heart bypass then you forget the simple things.. . Oh dear.
Cheers Trevor
Old 12-06-2017   #11
murphyv310's Avatar
Here is a screen shot off torque.
Didn't work through the app.
Here's a photo. I whipped out the sensor and cleaned it with carb cleaner and the codes have now gone but I get this message now.
Still no MIL light !!!
Cheers Trevor
Old 12-06-2017   #12
I don't use torque.
It doesn't look very useful .
Which sensor did you attempt to clean with carb cleaner?
Did it look sooty or white?
Old 12-06-2017   #13
What were the pxxxx codes before they disappeared?
Old 12-06-2017   #14
murphyv310's Avatar
The first sensor pre cat. It was pretty sooty. Funny I replaced the air filter at the same time as the plugs, it was really filthy. As far as I can tell although the book was stamped the 18000 mile service was never done.
Alfa Obd now reports on the live data when the engine is nearly at full operating temperature that both sensors are now closed loop which is correct, previously sensor 1 stayed open loop. Will give the car a run tomorrow and see how it feels.
Cheers Trevor
Old 12-06-2017   #15
Good luck tomorrow.
Iffy wiring to the regulating lambda sensor that you removed and replaced perhaps.
Thread Tools
(T) Fuse number and location issues. mwaite1985 Grande Punto 0 22-12-2013 23:09
fuse number/location bauer110480 Lets Talk FIAT 1 21-01-2011 02:10
(T) Fuse location number for horn Jonny29 Grande Punto 7 29-12-2010 19:41
acceleration flat spots & lambda light,....MAF, lambda sensor, fuel pressure regulator,.?? nico FIAT Boo Archives 0 10-07-2008 19:56
(T) Bravo 1.6SX Lambda Sensor Part Number bravosx Bravo / Brava 2 27-10-2006 02:56
