Thread Tools
Old 05-06-2017   #1
Panda strange fuel gauge behaviour.
Hi all,
My wife and I just replaced our 05 plate Honda Jazz with a 14 plate Panda 0.9 Multiair Turbo, Dualogic, lounge model.
Great car been running fine, had it for just over 2 weeks. The wife has just phoned me after a refuel on the way to work, she filled the tank but the gauge stayed at empty for around 30mins before it registered full and the range stayed at 50 miles then jumped to just under 400.
Anyone any experience of this? Just a glitch? I do have a few months dealer warranty.
IrishRyan is offline Reply With Quote Quote
Old 05-06-2017   #2
Re: Panda strange fuel gauge behaviour.
Sounds like the float in the fuel tank for the fuel gauge sender was stuck down and then freed itself.
If it does the same next fill report it to dealer under warranty.
The part could be quite expensive so worth keeping on top of.
jackwhoo is offline Reply With Quote Quote
Old 05-06-2017   #3
Ill keep an eye on it, ill also stick some fuel cleaner through it just in case, got a 3 month warranty when I purchased the car from Arnold Clark Fiat in Perth. Hopefully its just a one off.
Old 05-06-2017   #4
Full Circle
Mercky has donated!
Ireland
Quote Originally Posted by IrishRyan View Post
I think I'd avoid using any additives in a twinair
Likes JCarp16 liked this post
Mercky is offline Reply With Quote Quote
Old 05-06-2017   #5
Ok ill avoid that, ill just keep an eye on it.
Old 05-06-2017   #6
muttleysdad has donated!
Might be worth not letting get too far down before refilling.
muttleysdad is offline Reply With Quote Quote
Old 05-06-2017   #7
You think it might be a case of the float resting for to long on the sender, kind of bottomed out? Stuck in to low a position?
Old 05-06-2017   #8
It shouldn't stick, no matter how low you run the tank.
Likes jackwhoo liked this post
Barchetta LE (no 2468), 1998, Silver with Red Hood and Red Leather Interior, Hardtop, Wind-stop, Novitec SS Exhaust
Panda Cross Twinair, 15 Reg, in glorious Yellow , replacing a much-loved yellow DS3 DSport THP
gar074 is offline Reply With Quote Quote
Old 05-06-2017   #9
I overfilled the first car I owned. 2 days later I assume the level dropped enough to dry out the float or similar. I wasn't worried as knew it was full and I was only doing 40 miles per week. If it goes again, just keep adding fuel fairly often until you can take it to be looked at.
Al D is offline Reply With Quote Quote
Old 06-06-2017   #10
As GAR074 said it shouldn't stick at any position but you could have a tight spot towards the bottom. I've seen it occasionally when a car has been stood for a while with little or no fuel in the tank. I think condensation gets in and rusts the mechanism a little. With any luck it'll work itself back to normal after a couple of fill ups.
Old 12-08-2017   #11
I have just filled my 2012 panda to the brim. Was just under half full and I never let it run low on fuel. Gauge showed one bar over half full then jumped a bit.I've stopped and restarted, it's moved again but still only showing 3/4 full.
Jamie carman is offline Reply With Quote Quote
Old 12-08-2017   #12
Haha whilst I was typing my post gauge has jumped to full (engine running) hoping it's temp stuck floato as mentioned in other posts!
Old 13-08-2017   #13
Goudrons has donated!
Hi all,
I don't understand what the problem is?
I've never known this to happen to me!
Likes JCarp16, Mercky, Ventmore liked this post
Goudrons is offline Reply With Quote Quote
Old 2 Weeks Ago   #14
Trader Rating: 1
petercresswell has donated!
petercresswell is an honorary friend of the forum :)
B silly electronic gauges at the mercy of B silly ECU.. What was wrong with the old fashioned way...... I think the sender unit can hover between one bar and another and may move up after a wobble of the float.
petercresswell is offline Reply With Quote Quote
Thread Tools
(T) Smell of petrol and strange fuel gauge readings Qwerty123il Cinquecento / Seicento 6 18-01-2011 22:10
(T) Panda Fuel sender (fuel gauge) broken (also marbella) pandamonius_maximus Panda (Classic) 5 25-09-2010 09:50
(T) Strange temperature gauge behaviour puntodeltathema Bravo / Brava 7 06-09-2007 19:05
(T) Strange Behaviour Big Black Stilo Stilo 2 30-05-2006 23:20
(G) Strange Behaviour Peter Lloyd Stilo 3 27-03-2006 10:30
