Phils panda Member Parked in the garage Joined Jan 18, 2017 Messages 357 Points 114 May 26, 2017 #1 After the oil change does the oil temp sensor need resetting in the ecu if so why..
G gar074 Prominent member Joined Mar 26, 2007 Messages 2,983 Points 749 Location Beccles, Suffolk May 26, 2017 #2 Can't see why, unless it's been running stupidly hot, in which case it's presumably FUBAR'd anyway.
OP OP Phils panda Member Parked in the garage Joined Jan 18, 2017 Messages 357 Points 114 May 27, 2017 #3 Its the oil degradation setting in the ecu that some one said needs a reset.
Squadrone Rosso Small Fiat Fanatic Parked in the garage Joined Dec 2, 2003 Messages 1,278 Points 335 Location Nr.Neath & Swansea, Wales May 27, 2017 #4 Phils panda said: Its the oil degradation setting in the ecu that some one said needs a reset. Click to expand... Doesn't apply to petrol cars.
OP OP Phils panda Member Parked in the garage Joined Jan 18, 2017 Messages 357 Points 114 May 28, 2017 #5 I did think it was only on the diesel cars ,dpf and all that!
B berzins42 New member Joined Jun 11, 2017 Messages 7 Points 1 Jun 11, 2017 #6 you can reset only service in IPC.
