I'd be taking it back and demanding they mend it this time, not break it. Arrive at service reception at a busy time, lots of other customers there. Talk slightly louder than usual, but just persistent, not rude or angry. Gets their attention.
So far I would say that throttle response is not what it used to be and there are now definite new flat spots when trying to nip quickly out of junctions. Also, when cruising along at around 30 to 40mph speed limits along flat, or slightly downhill, roads the engine now has periods of not being able to make its mind up whether to provide power or to idle. The symptom being that the car can now have very obvious periods of surging and slowing - similar to if you were dipping the clutch as you were driving along.
This would seriously p*ss me off if it were my car.
He's not the only one who has experienced that it seems https://www.theguardian.com/money/2...skoda-seat-emissions-fix-left-car-undriveableI've heard of driveability issues with VW that have been "reprogrammed" the neighbours sons Golf with the 1.6 diesel engine has been a nightmare since.
It's happened!
My 4x4 went in for it's first annual service at the end of last week and the snappily titled "Vehicle Service Campaign Notification - FIAT Panda 4x4 with 1.3 MultiJet Euro 6 Engine - Engine Control Module Software Update -Campaign Ref 6026" update was applied.
So not too impressed, but have only been out in it about 5 times since it was done, so it may be too soon to say and things might bed in.
There has always been an occasional bit of a flat spot when pulling out of the end of our street that I put down to turbo lag type issues, but it wasn't nearly so noticable as it is now. It's as if the update has enhanced the negative characteristics.
So..... Anyone else had similar experiences, or know if the ECU might still be learning and things might bed in from here, or know if this software update can be backed out?
Yours grumpily!
Sorry to hear the update's made things worse for you mate, but I'm so glad I came across your post.
I've refused the update so far as I figured less emissions probably equals less power. However, my 4x4 has had flat spots and hesitations pretty much since new, and in recent months they seem to have gotten worse. In the last 3 months, it's spent around 4 weeks at the dealers, and they still can't track down the fault, and in actual fact, they've concluded that there's nothing wrong with it.
As they can't find fault with it, but I'm still insisting there's an issue, they've suggested that the software update could be worth a try, but after reading your post, there's no chance I'll be letting them apply it.
Also, after reading that you've always had flat spots, I'm kind of wondering if it's just a characteristic of the car that maybe bothers some people more than others.
Well...........
My Panda went back to the dealer and we went out for a very pleasant drive with a senior mechanic at the wheel and me as a passenger. Of course, she was on her very best behaviour and the intermittent issue was not showing and no progress was made.
There was a glow plug error noted a day or two before the visit and they hooked her up to their ECU reader and it was noted that there was an issue with cylinder 3 glow plug. As I think these plugs are only used to heat the cylinders prior to ignition, I doubted that would cause the issue.
She went back in to get the plug replaced and I asked them to have another look - which they did and found nothing again. It sounds like they are not willing to do anything unless they can find something to poke.
Since the plug was replaced she has been much better, which seems strange, but there is definitely still an intermittent issue. You can tell as soon as you start her up whether she is going to play along, or not. The engine is far more eager to rev, sounds healthier and just feels right underfoot. Unfortunately I have not been able to identify any logic to why she is absolutely fine sometimes and then not at others, to varying degrees.
Whether the software update made the issue worse, I am not at all sure. It may well be the case that the failing glow plug was indeed causing confusion in the ECU and that it was making things worse - it all happened around the same time. As for the update reducing the power, I really can't say that I've noticed that at all and, for the majority of the time, she rattles along as nicely as before.
So things are better, and maybe back to as they were before the update, but there is definitely still an issue and, as you say, it may just be a “characteristic” that I'll have to live with - until the fault comes on and stays on until I can get her to the dealer..
It does sound like very similar issues and it may well be worth starting a new thread, especially as they may not be related to the software update.
The pedal was one of the possible culprits, but it looks like your dealer swapping that out has made that less likely. It's probably the same pedal gubbins as in all the other current Panda models, and likely in many other cars. That being the case, it would probably be happening elsewhere - which brings us back to the MTJ engine, the fuel input or the ECU.
I notice no difference from the car being cold, or warm, or having sat for a while. Whilst the engine is under load, and having to work to keep a steady speed or accelerate, it seems to be fine. It's only really noticeable when going along flat, or slightly downhill bits, or when coming out of junctions. If the engine isn’t under load and the pedal position hasn’t moved, or has been up and is then going down again, there are times when engine doesn't seem to be able to quickly decide what to do. The revs then seem to monetarily drop and you can feel the power surge off/on if moving, or it will stutter if coming out of a junction. Once she has made her mind up, then off she goes, albeit maybe not quite as strongly and smoothly as she normally would when she’s working well. All very frustrating.
Sorry. My last post refers to petrol engines, I forgot we were discussing diesels.
