I have finally fitted the UR towbar and Right Connections loom to the Panda.
The towbar install was really easy - about 2 hours, taking my time. The only thing was the instructions were a bit vague about how the trailer plug bracket was supposed to be fitted, so it took me a few goes to get it in the spot I thought it should be.
Fitting the Right Connections loom (which UM supplied with the towbar) took me a bit longer - about 3 hours. A few connectors were hard to remove and I soldered other connections as I don't like to leave it to chance with connectors just crimped. But the loom is very well designed and it was mostly plug and play.
The end result is a good fit and looks like it was designed by the factory.
