- May 10, 2010
- 2,669
- 797
Ever since my little play in the dirt, my 4x4 TA has had noisy, gritty brakes.
I could feel/hear a gritty, gentle grinding when applying the brakes and in reverse, the N/S front and both rear brakes hooted like a demented owl, quite loudly, particularly when a little steering input was applied (parallel parking).
As per usual, the dealer booked me in to look at it sometime in 2214 after stating the usual "never heard of that before", so I decided to have a look myself as the hooting and grinding was effecting my fillings!
Seems the factory have saved a little and built up the brakes completely dry, not a spot of brake grease or copperslip in sight.
I stripped them down and noticed on the front, the top locating lug on the pads has been slapping on the caliper carrier at the top (obvious it's slapping up the top as it drags the pads upwards as it goes back in reverse) and started to wear a dint in the carrier.
I cleaned it all up with some brake cleaner, wire wool and some fine grit paper to smooth the edges of the dints off the carrier and liberally copperslipped up the contact points between pad and carrier. (both on the pads lugs and carrier).
The front caliper is held on to the carrier with some 7mm Allen key pins under a couple of plastic covers that pop off, these are the pins the caliper floats on and were bone dry, these just unscrew and got some copper slip too, as did the contact points of the spring clip that acts as an "anti rattle" on the outside of the front calipers that are a bugger to get back in the little holes.
At the rear the pads locating lugs are shimmed with some sort of "anti rattle" pieces top and bottom, springy metal shims coloured gold.
When cleaned off, I could make out where the pads contact the shims and rub/vibrate as the gold coating has worn off.
Both sides of the shims have this coating worn due to the different contact points whether going forwards and backwards, so it's easy to identify where the problem is and where to apply the copperslip.
Again, copperslip on both sides of the shims (and carrier) after cleaning well saw them clipped back in with a dab of the stuff on the contact points of the pad's lugs to shims.
The pins on the rears under the rubber covers that the caliper "floats" on did have evidence that as some point in the build they may have "smelt" a little brake grease, so more copperslip when on those and the lot built back up.
On neither front or back did I remove the carriers from the hubs as I had good access underneath via a lift to get at and clean both sides of the carriers well enough.
I was careful when applying the grease as not to contaminate the discs and pads friction material, though the backs of the pads did get a good coating, even though the pad backs have a anti rattle coating adhered to them.
All in all an hour and a half job that cost me less than the fuel and time to the dealer and back.
At just over a fiver for a can of brake cleaner and a 20g tube of copperslip (enough to do them twice) was a good result.
Now the brakes are super smooth, the gritty feeling has gone as have my demented owls and it should stay like that for a lot longer that the 1800 miles I've done so far.
