I have a twin air 4x4 three years old and stop/start stopped working recently. I disconnected the quick release on the negative side of the battery and also what appears to be a connection on the negative side of the battery for the stop/start. This is a plastic plug with small tab you press to disconnect the sensor cable. Left both disconnected for 10 mins. Reconnected by plugging sensor connector in again followed by reconnecting the quick release connection. Drove car for around 5 miles to ensure engine warmed up and then stopped to check if system working. Bingo.....working again.
NB...because battery disconnected you need to reset clock and date etc etc
