General So, will i get use to a TwinAir 85.
The Centre
I like the new Panda, but the TA 85 is still keeping me from changing.
I want improve performance compare to my tuned 79 hp Panda 169 1.2 ltr.
A heavier 312 with 1.2 ltr does not do the trick IMHO.
Tuning wise, only turbo-ing the 1.2 ltr would bring more performance.
Have my sight on a black TA 85 Lounge.
should be a good fun car - but maybe not as reliable over it's lifetime,
charlie
I think better wheels and tyres are a good idea, I've started chucking my Black TA Panda about a bit now is has nearly 7000 miles on the clock.
It's got plenty of go, but the grip levels don't really match the speed capability if you see what I mean.
It sort of understeers / just plain 4 wheel slides across the surface!
It's great fun though
A set of H&R spring would improve the handling a lot.
https://www.fiatforum.com/panda-iii/305376-h-r-2012-fiat-panda.html
I think a 85 TwinAir Turbo could easaly reach 130 hp with a Hybrid turbo, meaning:
With the following specific optimizations applied
  • State-of-the-art “Extended Tip” compressor wheel
  • 5-axis CNC Re-profiled compressor housing and backplate
  • 5-axis CNC Re-profiled turbine housing
  • Special turbine wheel
  • Optimized clearances
  • Modified actuator
  • Uprated bearing
  • Superior Balancing (less than 0.05gmm)
So i have take the plunge and bought this yesterday 85 TA Lounge. :)
First changes will be, Novitec lowered and Black 16" wheels.;)
