The FIAT Forum
Go Back   The FIAT Forum > Guides > Panda Guides
Comment
Article Tools Search this Article
<!-- google_ad_section_start -->Steering Wheel Replacement<!-- google_ad_section_end -->
Published by Steven
20-02-2007
Removal of the old Steering Wheel
We all know that the original Panda steering wheels are small and skinny. For those of us that use our Pandas every day, a Fiat Cinquecento Sporting wheel is easy to fit and improves comfort. Here's how to do it.
Firstly, disconnect the battery. If you don't mind disturbing the neighbours due to the horn constantly blowing then leave the battery connected.
Next, ensure the steering wheel is dead centre with the wheels straight ahead, this makes life simpler later on.
Next, prise off the horn push in the centre of the wheel. I found this was easily done using two small flat blade screwdrivers, it just pops out.
Once removed you can see the 24mm nut holding the wheel in place, the springs which operate the horn and the washer below the nut. Remove the springs and set them aside.
Next, get a 24mm spanner or socket and loosen the nut carefully. It may be tight, but it will loosen. Be careful not to round the edges. Once off set it with the springs and then remove the washer. Don't lose them!
Then simply pull the wheel towards you, it will come away from the steering column easily.
Contents
Article Tools
<< <    Next Page: Fitting the new Steering Wheel (Page 1 of 2)    >  >>
Old 24-06-2007
dave's Avatar
Trader Rating: (9)
dave has donated! Saint Kitts and Nevis
Re: Steering Wheel Replacement
i had to make an adjustment on mine so the indicator turn off bit still worked,
Binki
dave is offline
Old 24-06-2007
Moderator
Steven's Avatar
Trader Rating: (7)
Steven has donated!
Barry did as well Dave. It seems that early Cinq Sporting wheels bolt straight on but later wheels need an adjustment made.
Steven is offline
Old 24-06-2007
dave's Avatar
Trader Rating: (9)
mine was off an m reg
Binki
dave is offline
Comment
Currently Active Users Viewing This Article: 1 (0 members and 1 guests)
Search this Article:
You may not post new articles
You may not post comments
vB code is On
Article Article Starter Category Comments Last Post
Steering Wheel Wont Turn!!! zoe3558 Punto 19 01-11-2006 22:54
Paddle + broke of, need help taking steering wheel apart dmarkie Stilo > Technical 1 07-09-2006 21:02
Steering wheel revamp / replacement dve83 Uno > Styling 1 06-09-2006 22:58
Steering wheel Werner Punto > Technical 2 17-07-2006 10:20
Anyone fitted an aftermarket steering wheel?? My Little Panda Panda (Classic) 14 04-04-2006 18:16
