The FIAT Forum
Go Back   The FIAT Forum > Guides > Panda Guides
Comment
Article Tools Search this Article
<!-- google_ad_section_start -->Adjust handbrake cable slack<!-- google_ad_section_end -->
Published by Alan.D
09-02-2007
This job is directed to those Panda's that have non-adjustable handbrake shoes. If your panda has adjustable shoes they should be adjusted in the first instance.
It couldn't be much simpler
Time taken less than 5 min.
Tools required 2 x 13mm spanners.
Same rules apply when under a car ALWAYS use axle stands and have the car on level ground also chock the wheels that remain on the ground.
OK my panda was already in the air so whilst there decided to do this.
Over time the cable stretches and as it does so the handbrake lever is pulled further into the air when applied until the MOT man says enough is enough and fails it.
Set the handbrake to the first notch/ratchet on the lever the rear wheels when in the air should have just a little resistance, if they are spinning freely adjust the nuts shown below towards the front of the car till the rear wheels just start to show resistance.
The nut at the front adjusts the cable, the other is a lock nut to prevent the adjusting nut from freeing itself.
Once the forward nut has been adjusted, whilst holding it in position with a 13mm spanner using a second 13mm spanner tighten the second nut to the first.
Job done.
Article Tools
Comment
Currently Active Users Viewing This Article: 1 (0 members and 1 guests)
Search this Article:
You may not post new articles
You may not post comments
vB code is On
Article Article Starter Category Comments Last Post
mk2 punto handbrake cable on left gone slack ?? PuntoMk2Goldie Punto > Technical 3 03-04-2006 13:49
How do I adjust the handbrake cable? rick_p Cinq/Sei > Technical 14 09-08-2004 17:12
how do u adjust the cable (handbrake) STEVEHANKIE Bravo/a > Technical 4 01-06-2004 03:23
