The FIAT Forum
Go Back   The FIAT Forum > Guides > Panda Guides
Comment
Article Tools Search this Article
<!-- google_ad_section_start -->Front Wheel Hub / Bearing Replacement<!-- google_ad_section_end -->
Published by Alan.D
04-11-2005
Talking Front Wheel Hub / Bearing Replacement
It will make no difference whether the panda is 2 or 4wd for this procedure.
Tools Required:-
  • Torque wrench
  • 32,19,17,13 & long 12mm sockets
  • 19,17,13mm Ring spaners
  • Good quality ball joint removal tool (This is optional as there are two methods of removing the bearing this procedure does not require the ball joints to be removed).
  • Knackered large screwdriver.
  • Small screwdriver.
  • Small or large hammer
  • Axle stand.
  • Plenty coffee if it's cold.
So Sort out your tools (you don't need as many as shown) and your shiny new Hub bearing.
Contents
Article Tools
<< <    Next Page: Getting Started (Page 1 of 4)    >  >>
The following 2 users say "Thank You!" to Alan.D for this useful post:
Oingo (19-03-2008), woz (09-12-2007)
Comment
Currently Active Users Viewing This Article: 1 (0 members and 1 guests)
Search this Article:
You may not post new articles
You may not post comments
vB code is On
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Article Article Starter Category Comments Last Post
Updated price list 21/04/2004 Body Stylist Punto > Styling 30 09-04-2005 17:02
steering wheel nut replacement marky23 Punto > Technical 7 09-04-2005 12:12
matal scratching noise from front wheel Lemzip Punto > Technical 9 12-06-2004 20:39
Clicking coming from the front right wheel. lashlondon Uno > Technical 11 09-10-2003 22:30
front speaker replacement. cmorrison I.C.E 0 16-06-2003 05:36
