Comment
Guide Tools
<!-- google_ad_section_start -->How to remove and replace electric tailgate handle<!-- google_ad_section_end -->
Published by Herts Hillhopper
07-03-2010
Unrated
User Rated:Unrated
OK, the long-awaited 'How to' guide on replacing the tailgate handle for Panda's with the misbehaving electric release. (This guide will also let you locate the plug to temporarily disable the boot release when it starts playing up --follow steps 01 to 04 to remove trim, and disconnect plug in steps 07 and 08 only. Note that this will also disconnect the numberplate lights so is only a temporary fix.)
The part itself (the complete bootlid handle, which comes with numberplate lights and even the bulbs!) will be needed from the dealer. The new part is supplied in grey primer and will need spraying to suit before being fitted. Before spraying, the numberplate lights and the rubber seals on the back need removing and various parts (noteably the wiring and the microswitch itself) need masking off.
Before you start, make sure the whole car is unlocked and the key is with you outside the car.
Open the boot and locate and remove the two Allen screws (left) inside the internal handles (right, one each side, 5mm Allen key)
ID:	74786Click image for larger version
Starting at the centre by the boot catch, pull down hard on the plastic trim to release the plastic clips (left) and work around the edges both ways to release them all (right). There is one in the very centre too, by the wiper motor. Put the trim panel to one side. (If any of teh clips break they can be easily replaced - most car spares shops sell similar clips)
ID:	74787Click image for larger version
There are four 10mm nuts to be removed (two can be seen in the left pic- one above my finger and one to the right). Take care not to drop them as they unscrew (magnetic socket helps here - right pic)
ID:	74789Click image for larger version
Twist the yellow retaining clip that secures the metal control rod to the key release through 90 degrees and release the rod. (Note: if you now shut the boot it can only be opened with the button on the remote -- best not to shut it!)
Now you need to unplug the wiring - find the white connector seen in the left pic. Release the plug (middle pic) by pressing the little latch that holds it (my thumbnail is on it) and slide away. Then insert a small flat screwdriver between the white plug left attached to the bootlid and the plastic retainer fitting (right pic) that holds it. The screwdriver will lift a retaining catch and the plug can then be slid off the retainer.
ID:	74792Click image for larger version
ID:	74793Click image for larger version
Now, with one hand holding the external handle, use your other hand to press the two plastic release clips (see pic -- they will be the colour of your car, so not necessarily red as here, and are roughly in line with the number plate lights).
Lower the bootlid but don't shut it! (I left a coat lying across the catch to prevent it closing fully) Gently pull the handle away from the tailgate, easing the wiring and white plug though, and sliding to the right to pass the key release lever through.
With the bootlid open, the rear shelf is an ideal place to remove the lock barrel. Prise away the C-clip holding it (left pic screwdriver being used to slide the C-clip. Note, this does not need to be fully removed, just slid out by about 4-5mm as in the photo). Put the key completely into the lock (the barrel cannot be removed without the key) and twist the key and pull to withdraw the barrel (right pic)
ID:	74797Click image for larger version
Fit the lock into the new handle, and then reverse the operations above to fit the new handle to the car. Remember to refit the metal control rod to the key release. When refitting the plastic trim panel, start by locating the two white clips in the corners nearest the rear window glass, then work around the edges. Finally, a good sharp thump in the centre will fix the middle clip.
The last pic shows the dirt in the old handle around the microswitch after 5 years on the road. It has been suggested in previous posts that maybe a spray of WD40 would prevent this -- I suspect that it would actually make it worse by allowing more dirt to stick.
From start to end, including taking the photos, took less than half an hour.
Pete
(PS - if you find this useful, do remember to press the 'Thumbs up' button below)
I will also post (later) some photos of the new and the old handle in detail to identify what failed, and maybe a way of preventing it doing it again...)
Old 07-03-2010   #1
100hp
DavePanda100's Avatar
DavePanda100 has donated!
Re: How to remove and replace electric tailgate handle
I like the handle to pull the boot lid down. We get a bit of strapping on the 100hp
Thanks tipouno thanked for this post
Panda 100hp - Gone, the little scamp will be missed.
DavePanda100 is offline Reply With Quote Quote
Old 07-03-2010   #2
Twin Turbo powered :-)
udtrev's Avatar
udtrev has donated!
Bedeviled Plus Champion
They must have a couple of varations,
When my handle was replaced on my 1.2 they had a black one that matched the original.
It's a shame we cannot just cut the relevant wire from the plug so that the lights could be retained.
Trev
For all Chrysler help got to http://www.chryslerforum.co.uk/
udtrev is offline Reply With Quote Quote
Old 07-03-2010   #3
Mine's a 2005 model, and so far as I know they all had the two plastic handles inside the tailgate then (one each side). Is the webbing strap DavePanda talks about evidence of Fiat cost cutting on later models?
As for black vs painted, the 4x4 model is a sort of hybrid of trims from the Dynamic and the Eleganza - I think the painted boot handle was Eleganza spec (but I'm sure others will tell me I'm wrong!). Either way, dead chuffed to find one that had been 'hiding' in eBay since last August for just 15!
2013 Panda 4x4 :: North Herts :: Remember, if you find a post helpful, press the smiley face 'thanks' button below
Herts Hillhopper is offline Reply With Quote Quote
Old 07-03-2010   #4
Speed Reader of the Year!
Most Easterly Pandas's Avatar
Trader Rating: 2
Most Easterly Pandas has donated!
Bolivia
Quote Originally Posted by DavePanda100 View Post
Same on my 2009 Elegaza, got the strap option. TBH I prefer it to sisters Active with the handles.
Most Easterly Panda's - Panda'ing in East Anglia
Stockest of mk2 Panda Parts, PM for any parts requests
2 White Classic Panda Selecta's, 1989 Panda 750L,
2013 Toyota Prius Plug-In & 2009 Panda Eleganza
Most Easterly Pandas is offline Reply With Quote Quote
Old 07-03-2010   #5
udtrev's Avatar
udtrev has donated!
Just checked, I also have the strap
Old 07-03-2010   #6
Jai
Banned
Jai's Avatar
Trader Rating: 6
Jai has donated!
2004 eleganza, handle.
Thanks Most Easterly Pandas thanked for this post
47 days to go.....
Jai is offline Reply With Quote Quote
Old 07-03-2010   #7
ivantate has donated!
Good guide. Was the handle that one we discussed on another thread?
My Sporting has a black plastic unpainted handle.
It has a strap and from memory the boot lid trim is a furry carpety substance.
What does the old handle look like? any chance of just replacing the switch as a more cash friendly fix?
Reality: 55reg Idea Eleganza. The car in the facelift press release.
Dream: Panda Trekking.
ivantate is offline Reply With Quote Quote
Old 07-03-2010   #8
ben
The Boss
ben's Avatar
ben has donated!
ben is an honorary friend of the forum :)
King Pong Champion, e+Casino Blackjack Paper Champion, President vs Invaders Champion, Funny Clown vs Balloons Champion, Table Tennis 2.5D Champion
Taiwan
Congrats - the first ever Panda guide
my name is ben, i live in the east, i'm always working on the forum, i like pancakes.
MAKE MITTENS FAMOUS - https://www.instagram.com/heymittens/
ben is offline Reply With Quote Quote
Old 07-03-2010   #9
Quote Originally Posted by ivantate View Post
See last photo - the microswitch is not replaceable. (I'll add some more shots of it later...) Also the moving parts of the handle had seized and what ever provided the 'spring' return function was also no more. So, sadly, not viable (I usually manage to mend things rather than replace, but not this time, I'm afraid)
Thanks Bald Silver Surfer thanked for this post
Old 09-03-2010   #10
You're a star Pete for getting that up. Well done, now I can see why FIAT stealership want 230 for it though. Someone like me would always end up with excess screws! I can't understand why they didn't make the micros switch changeable though!
My 4x4 is a 2005 as well and has the dog unfriendly black carpety stuff with a tug cord. Rather have the hard plastic any day!
Ross
Bald Silver Surfer is offline Reply With Quote Quote
Old 13-02-2011   #11
anyone know the part number of the offending handle unit complete? I tried ePer, but it came back with various handles and various prices.
Ned to fix mine before I rip the damn thing off for constantly opening and keeps making the opening noise!
2005 Fiat Panda Dynamic MultiJet
2009 Fiat Panda Active Eco
1988 Fiat Uno MK1 - rotting away outside until I can get it in the garage to rebuild after years of faithful service.
Lord Azrael is offline Reply With Quote Quote
Old 18-06-2011   #12
Actually, as I`m a short person, the strap is better for me. I only found it by accident, wondering what was hangling loose at first
2011 Panda Dynamic 1.2, leather wheel & parking sensors extra
Jerseywurzel is offline Reply With Quote Quote
Old 15-08-2012   #13
France
Quote Originally Posted by udtrev View Post
Actually you can, I did it on mine because the boot was constantly opening.
BillySpleen is offline Reply With Quote Quote
Old 17-04-2015   #14
is annoying.
BlueDan's Avatar
BlueDan has donated!
Fixed mine today (for how long...?)
Followed the guide to remove the handle/light/switch assembly from the boot lid.
Washed all the dirt out (bear in mind the area the switch is in is not sealed from the elements, so get in with warm water, soap and a brush).
I found that pushing the switch forward a bit with a screwdriver meant that the moving part would make better physical contact with it (first part of this video). So I doubled over a piece of Gorilla Tape and wedged that in behind it. In the second part of the video you can hear (volume up) that the switch is now activated when pressing at any part of the handle
29-01-2005 - 21-07-2012 1998 Imola Blue Cinquecento Sporting
09-06-2012 2008 Crossover Black Panda 100HP
BlueDan is offline Reply With Quote Quote
Comment
Guide Tools
(G) Needing to aquire a tailgate lock/handle/key robdodd Marea 0 04-02-2008 20:04
(G) stilo MW tailgate handle purpleronnie Stilo 6 10-10-2006 13:31
(G) Rear Tailgate Handle werdna Marea 6 09-05-2006 17:44
(T) Tailgate handle repair irene Bravo / Brava 3 14-05-2005 09:56
(T) Help needed - removing 'tailgate handle' + walders Bravo / Brava 0 11-04-2003 15:57
