| temperature i just got a 4x4 1.1 model 1993. I will like to know what temperature is normal to have when i drive it on the high way thanks
| Re: temperature generally it's healthy to see it somewhere around the 80-90 mark... regardless of speed, it will only really increase if you are stuck in slow moving traffic
| | #3 | ||
| Re: temperature It is cold (about -3) at the moment though, mine usually sits between 70 - 90 but went no higher than 70 tonight even during a 30 minute drive Welcome to the forum
__________________ * * * Pandarus * * * (aka MARTIN) FIATLESS BUT STILL LOVING ANYTHING PANDA!!! 2002 Skoda Fabia Comfort Estate 1.4 MPI | |||
| | #4 | ||
| Re: temperature hi there floyd tonight was running at 80 , but normally nearer to 90 anything over and panic !!! good timing on getting a 4x4... anyway welcome to our clan gina XXX
| | #5 | ||
| Re: temperature when i drive over 110 kilometers per hour the temperature goes 95c is that ok? the car it goes well the engine sounds good. oils are fresh. i went up to the mountain on 2500 meters no problem. any suggestions thanks
| | #6 | ||
| Re: temperature
| | #7 | ||
| Re: temperature
| | #8 | |||
| Re: temperature
Its ok but your little engine might benifit from a coolent change.And check when your fan cuts in?Damien.
__________________ PANDA 4X4 FUN IN THE SUN | ||||
| | #9 | ||
| Moderator | Re: temperature One of the first jobs I do to any Panda I buy is to flush the coolant and replace the thermostat. It's so cheap and easy and makes a real difference to the car's performance. Have a look at my post here: http://www.fiatforum.com/showpost.ph...5&postcount=48
| | arc | Cinquecento / Seicento | 35 | 29-07-2007 01:15 |
| | mr_craig | Punto | 0 | 01-09-2006 13:04 |
| | nomatter | Cinquecento / Seicento | 22 | 13-01-2006 22:54 |
| | coedkernew | Punto | 4 | 30-08-2005 16:10 |
| | pikkumies | Uno | 3 | 29-08-2003 20:34 |
