Auguste
Pandaman Paul's rust free panda makes me wonder something ...
My 93 1000 Fire was pretty much rust free or appeared to be when I bought it. After blowing the head gasket and letting it sit for 60 days while I worked on it, a small rust spot started bubbling up on the join between the front right pannel and the right door frame.
Not too much, now about 7 cm long and pretty thin but the bubbles are bothering me.
In my youth, as a deck ape on some fine old rust buckets, we'd break out the needle guns and chip out the rust, grind it down to bare metal, and coat it with red lead, then paint over it. I figure I could do the same and hopefully stop it from going further, but I'd end up with a patch of mismatched paint.
I figure with all the talk of rust on this forum, someone must know if getting the trouble spot cleaned up and primed is good enough to prevent futher rust damange? If so, are the currently avilable areosol primers good for this? Can you use a brush and prime it (no overspray) and what with? I know it won't look the best but ...
(God, this sounds like panda dentistry).
Auguste
Auguste
