If there's no servo it will be the same as mine Chris. However, depending on your technical ability/willingness to get your hands dirty, the newer brake cylinders will fit. (The only reason I can't fit them to the 'Rat is because of the chassis fouling the reservoir). You'd need to make some new brake pipes though. Most good motor factors will do this for you very very cheaply. The pipe and fittings cost peanuts.
