The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Panda (Classic)
Old 18-05-2006   #1
Trader Rating: (0)
A quick summary of engine/trans removal from 4x4 anyone?
Hi again,
After the "tree tragedy", I picked up a wrecked 4x4, smashed in right front inner, outer, fender and chassis. If I remove and re-install the engine myself, I'll save a lot of bucks at the body shop.
Soooo....this Sat morning, I need to remove the engine (and trans?) out of the 4x4 for bodywork repair of the inner fender, frame etc.
Can someone run down the procedure? I'm ok with the ancillaries, but need guidance on the engine/trans, e.g do I need to remove the axles? etc.
Do I need any special tools for removing the rear driveshaft?
This will be at the body shop, so I have full access to most air tools, winch etc...
regards
nikos
zucherro is offline
Old 18-05-2006   #2
Road Rat Pilot!
default_user's Avatar
Trader Rating: (2)
default_user has donated! United Kingdom
Re: A quick summary of engine/trans removal from 4x4 anyone?
Hi Zucherro.
I have recently done this (twice in the same week!) so I have a little knowledge and experience.
You've already said you're ok with the ancillaries so I'll assume you can get as far as just needing to undo the engine mounts and hoist it out. None of the following requires special tools.
You DO need to remove both front drive shafts and disconnect the propshaft at the rear of the gearbox, as well as the gear linkages and 4x4 selector linkage. Removing the drive shafts involves partly dismantling the front suspension on both sides so you have enough room to swing the hubs out and off the splined drive at the hub end. The diff end of each shaft is only held in by fact that the shafts can't go anywhere when everything is assembled but you'll need to undo the gaiter bolts to completely withdraw them. There are three on each gaiter securing ring and are fairly easy to remove. Lots of oil will spill out at this point. The gear linkages and 4x4 selector lever can all be easily popped off at the gearbox underneath as they are just push on connectors. You'll need a flat screwdriver to lever them off and a set of grips to pop them back on when you need to.
Now the engine and gearbox should only be held in with it's three mounts. The forward two are easy to access and dismantle. The rear one, which is located right at the back of the transfer box extension for the 4x4 mode is quite difficult to undo. There is a long bolt running right throught it from top to bottom. This clamps a curled section of metal plate (obvious what I mean when you lie under the car and have a look). The best way to tackle this is to get a spanner on the top of the bolt and loosen the nut at the bottom. This will release the plate but as it's curled around the bolt it still holds the gearbox up. When you have suspended the engine and removed the other two mounts all you need to do is move the whole assembly back a little to detach the curled plate from the mounting bolt. Lifting the whole assembly out of the bay is tricky to as you have to tilt it gearbox end down while you lift. More oil will spill out at this point too. Have fun!
Hope this helps.
Cheers,
Rick
Rick.
The Road Rat, or Satans Rodent as it has now been dubbed, is a kit car based on Panda 4x4 mechanical components.
Chart it's rebuild progress here.
default_user is offline
Old 18-05-2006   #3
Ban the Mongol rally
Alan.D's Avatar
Trader Rating: (4)
Alan.D has donated! Italy
Another option is dropping it all & pulling it underneith the car if you want that method just ask.
Before doing anything....
FFS DISCONNECT THE BATTERY.
Alan.D is online now
Old 18-05-2006   #4
Don't polish it, DRIVE IT
Trader Rating: (0)
pandafan has donated! United Kingdom
You beat me to it again !
So much easier to my way of thinking.
www.hawortharts.com
pandafan is offline
Old 18-05-2006   #5
Trader Rating: (1)
Tony M has donated!
Dropping it onto something with wheels or a draggable thing (canvas, piece of carpet... ) does seem to be so much easier than trying to lift it out.
Tony M is offline
Old 19-05-2006   #6
Road Rat Pilot!
Trader Rating: (2)
It depends on what equipment and facilities you have available and personal preference which way you do it. I did both engine removals with a hoist and just pushed the car back out of the way and lowered them onto the floor. To put the engine back in I found it easier to lift the front of the car and place the engine underneath and lower the car onto it. More involved though because I had to do two lifting operations. You could also split the engine and gearbox before you remove them to make getting the engine out easier. No doubt other people have approached it in slightly different ways.
Rick.
Old 19-05-2006   #7
Alan.D's Avatar
Trader Rating: (4)
Dropping it down you don't need any specialist tools although I found a step ladder & rubber mats most usefull (oh! er!) Just need to lift the car high enough on axle stands for both dropping & lifting.
Old 19-05-2006   #8
Trader Rating: (0)
Thanx for all the help all,
I will pull the engine from the top, as the front of the car is already dissassembled.
Looking at the axles, it seems that I have to undo the ball joints and tie-rod ends to pull out the axles...
thanx again,
nikos
zucherro is offline
Old 09-11-2006   #9
Trader Rating: (0)
A pic of cam side engine mount anyone?
Hi all,
Been a while.....
I'm finishing up on my 4x4 resurrection and I need a pic of the cam side engine mount as I think I've might have the metal bracket that bolts to the frame flipped. This is for a ~2000, 4x4, 1108 LHD vehicle....Has the cast/forged aluminum bracket that bolts to engine and then to the metal bracket and rubber that bolts to the frame...
Would appreciate it and I'll try to post some pics of the car...
thanx,
nikos
zucherro is offline
Old 09-11-2006   #10
Alan.D's Avatar
Trader Rating: (4)
Hope this helps.......
ID:	20692  Click image for larger version
Old 10-11-2006   #11
Trader Rating: (0)
Thanx for the response Alan,
Sure enough I had the pressed steel bracket that bolts to the frame flipped. I corrected that now everything seems kosher...
thanx again
nikos
zucherro is offline
Old 10-11-2006   #12
Alan.D's Avatar
Trader Rating: (4)
Good luck
Quick and easy spray paint removal D4NS Leisure Lounge 16 28-04-2005 08:13
Making a 4X4 out of a non 4X4 model?? NovaVan Panda (Classic) 34 16-03-2005 10:29
